Question about Cerwin Vega Audio Players & Recorders
I though i had a bad tweeter on one of my sl 12 cerwin vega speakers, replacing it didn't fix the problem still no sound coming from it,,, what else could it be? does anyone know, please help
    Genius:
  • 1,054 Answers
Sounds like a problem in the crossover
Posted on Dec 06, 2016
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Does it have the 1" tweeter? have you ever heard it before?
Posted on Jan 04, 2017
    Habit-Forming:
  • 62 Answers
I believe these speakers are fuse protected. If so, replace fuse with similar type.
Posted on Dec 26, 2016
SOURCE:
Where can I source a replacement tweeter for cerwin vega e-712
the exact replacement tweeter can be purchased from midwest speaker company
google it
Sep 27, 2012 | Cerwin Vega E-712 Main / Stereo Speaker
Replacement (upgrade) tweeters
go to a radio shack if not in stock ..than order one...i would suggest a piezo style ...about 8 bucks each...
Apr 22, 2011 | Cerwin Vega Cerwin-Vega V-12F Floor...
No sound coming out of speakers on my cerwin vega
spurdoggg,
It will be easy to pin point the problem. If your satellite speakers have been connect through the sub's in and output speaker connectors, disconnect them and connect them directly to the source of sound. If the speakers work its the crossover inside the sub enclosure. If the speakers do not work the speakers are blown.
Apr 28, 2010 | Cerwin Vega AVS-5.1 System
I have a Cerwin Vega E-315 speaker and the Woofer has stopped working. The Tweeter and Mid-Range still work just fine. I just do not get any sound from the Woofer.
Pull speaker so you can get to the terminals in back. Take an ohm meter and check the ohms of speake, a 4ohm speaker could measure up to 5ohms and still be good. If the reading is way off then it is blown. If speaker is good, then check the cross over thats in the speaker, some models put fuses on the units for protection, but mostley on the high frequency of the cross over, not the low.
Mar 06, 2010 | Cerwin Vega E-315 Speaker
Only voice from tweeter is coming, nothing from the mid-range and woofers. on cerwin vega v10f
bhurajiv,
Well it's a good thing that you are getting sound from the tweeter from the speaker cabinet with the problem, that eliminates one of the possible problems; your wires are connected!
If your other speaker sounds fine, the first thing to try is to swap your speaker wires with the one that sounds fine. If the problem speaker cabinet still only produces sound from the tweeter, the problem is within the speaker. If the problem goes away, the problem is from your electronics.
If the problem is within your speaker and it is still under warranty, find a authorized repair location (http://www.cerwinvega.com/service_center.php).
Problems within the speaker can only be one or more of the following: 1) The drivers not producing sound have been blown; played with either too much power and/or distortion. Distortion is created when you play your music too loud with a amp not able to reproduce what you are looking for in sound, the speaker itself can hear it before you can.
2) The speaker cabinet has a crossover inside which directs the proper sounds to the proper driver. This crossover can have components that have been broken be either #1 or from exsessive vibration.
3) There are wires inside of the speaker cabinet that have been disconnected. This can happen over time or if someone reaches inside of the cabinet through the port and pulls on the wires; like a young child or pet such as cats.
If the drivers in question just one day stopped producing sound, start with the easiest solution, #3 then #1 if you can suspect anyone could have played your speakers other than you.
To diagnose the problem, you first start by removing the woofer and confirm that all of the wires are connected and in good condition. While the woofer is removed, to eliminate that there is a problem with the speakers, temporarily connect the mid-range and woofer, one at a time, directly to the wire coming from your electontics, if they produce sound the problem is within the crossover network, if they do not produce sound, the problem is with the driver itself. Replacement parts should only be purchased directly from Cerwin Vega directly (http://www.cerwinvega.com/contact_us.php)
-Chris
Jan 25, 2010 | Cerwin Vega Cerwin-Vega V-10F Floor...
Cerwin-Vega 12'', no power
It should have a small fuse on the board between the transformer and the board. Check that first. If it is good see if the transformer is putting out any voltage. Two easy fixes that can be done in house...
Jan 01, 2010 | Cerwin Vega LW12 Subwoofer
DOES ANYONE KNOW WHERE I CAN GET A REPLACEMENT FOR A CERWIN VEGA
what kind of tweeter are you looking for as there are alot of different tweeters around madisound has a good selection also partsexpress.
Jan 01, 2010 | Cerwin Vega CLSC-15 Main / Stereo Speaker
279 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Ben Armstrong
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
