Question about Garden
Toro 824 model - won't start - fuel line blocked between shut off valve and priming button. Is there an inline fuel filter?
Bought a used Toro 824 Snow blower. Had bad fuel in it, cleaned all fuel out via tank drain and the bowl. Added new fuel. Took out spark plug and put fuel in the cylinder directly. Replaced spark plug. Fired engine. Started, then cut out. Repeated the above steps, started, then cut out after about 10 seconds. Will no longer stay on, thinking I pulled some debris into the fuel line and blocked it. Isolated that there is a blockage in the fuel line BEFORE the primer and AFTER the fuel shut off valve (but primer and shut off value are not blocked). Going to be taking it apart anticipating that the blockage in simply in the fuel line, but wondering if there is anything else inline before the primer, such as a fuel filter, that might be clogged? Thanks.
  • 3 Answers
SOURCE: My Mower won't stay started after it uses the gas that has been pushing into the mower via the primer bulb
either the magneto or the governor is damaged check them
Posted on May 30, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
SOURCE: Toro TimeCutter z4200 will not start
Toro Timecutter Z4200 mounts gas tank under seat and below carburetor. After first started, Z4200 will start OK again during mowing this period. But after some time passes (next mowing), gas evaporates from carburetor. Can run down battery using battery/starter getting gas backup through carburetor to start engine. This is poor Toro design, but good for service charges when replacing good components while trying to fix this problem.
Better solution is to add an outboard motor one-way squeeze bulb (approx. $15) between the fuel filter and the carburetor. Using the squeeze bulb for first start will prime the motor so that it will start without having to crank so long (which Toro says will burn up the starter). Toro saves $15/mower as well as selling new Z4200 starters.
Posted on Jun 04, 2009
bbreton
  • 437 Answers
SOURCE: PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Posted on Nov 11, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
How to prime fuel syystem on Case IH model 40 compact tractor
Every primer I have found is at the fuel filter. All the others, I opened an injector fuel line. Crank it till fuel comes out. Then it will start, Takes a minute, but will.
Feb 13, 2016 | Cars & Trucks
Toro power head 51944 won't prime
Replace primer bulb or line and filter running from bulb to fuel tank.
Apr 16, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
83 ford ranger carb backfire
Which engine and what type ignition system? How many miles on it? Timing chain or belt? don-ohio
Mar 24, 2017 | Ford Ranger Cars & Trucks
I have a Toro Time Cutter Z480 and it starts up but as soon as you move forward it stalls and there is a lot of thick smoke.
What you have is an engine that has a carburetor problem that has probably diluted the oil to the point that the crankcase is over-filled. Drain the oil and filter, then replace oil. Sometime the carburetors on these unit will become porous or cracked inside and will allow gas to enter the fuel bowl while the engine is not running. Some signs of this is that the engine will drag or static lock when you try to crank it over.
I've gone to the point to even put an inline fuel shut-off valve in the fuel line so that the fuel can be shut off when the engine is not running to temporarily deal with this problem until a new carburetor can be located and installed.
Aug 07, 2011 | Toro 48" 21hp Z Master Zero Turn Lawn...
I have a toro LX 500 Riding Mower with Kohler Courage 22 motor. I was cutting grass and it started hesitating and eventually shut off. It will start but only runs for a bout 30 sec to 1 min before it shuts...
When you had the fuel filter off, did gas flow freely from the hose? Sounds like maybe the tank has dirt in it blocking the fuel line. Other than that, maybe there is dirt in the carburetor bowl.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Toro Lawn Mower With Toro Power Tools
My Toro runs as long as the "prime" lasts then shuts off.
make sure your fuel lines are all clear and that you have nice and fresh fuel in your tank, check the cleanleness of your carb and needles
Jul 27, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
My Toro lawn mower (Tecumseh engine) is quitting on me.
defective check valve pull the tank and remove the fuel line replace the small inline filter on hose.
May 24, 2009 | Garden
First check to see if there is a fuel shutoff under the tank. On some models there is a fuel filter screen inside the tank where the fuel line connects to the tank. If niether of these work, R&R the carb.
Apr 08, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
