Question about Montgomery Ward Sewing Machines
I have a Montgomery Ward model 1934 sewing machine. The reverse button has no tension and the machine is stuck in reverse stitch mode. Can this be repaired?
  • Montgomery Ward Master
  • 12,278 Answers
You may want to take it for service. Could be the machine has seized with the reverse button stuck. May need to be disassembled.
Posted on Dec 06, 2016
My old Montgomery Ward sewing machine, m# 1957, acts like the needle mechanism is stuck, in the "bobbin refill" mode! The wheel won't budge. I have no book so don't know how to engage the needle arm!
As long as the bobbin winder is engaged, the machine will not sew. This is a safety feature.
Montgomery Ward Sewing Machine Instructions eHow
Check the large wheel on the right side of your machine. Is there a smaller wheel inside? On some machines, this is the mechanism that activates/deactivates the bobbin winder. Will that inner wheel turn? If so, check to see if that causes the machine to sew.
Apr 19, 2018 | Montgomery Ward Sewing Machines
I have a Montgomery ward sewing machine model number uhtj259a and I can't thread it right the thread keeps coming out of the needle when I try to sew
Be sure to pull at least 4 or 5 inches of thread through the needle before taking the first stitch. It is helpful to hold both thread tails in the left hand while slowly taking the first couple of stitches. It also helps to make sure the needle is at its highest point before taking the first stitch.
When threading, ALWAYS RAISE the presser foot and verify the thread path is correct.
https://www.youtube.com/watch?v=olXhSmoWM5s
http://montgomerywardsmanuals.com/Wards_Instruction_Manuals.htm
http://www.sewusa.com/Sewing_Machine_Manuals/Wards_Signature_Sewing_Machines.htm
http://www.ehow.com/how_7219808_montgomery-ward-sewing-machine-instructions.html
Sep 28, 2017 | Montgomery Ward Sewing Machines
How to thread an old Montgomery Ward sewing machine model 30 ? e
Search the internet for your machine make & model & threading instructions. You may not find your exact machine, but a lot of similar machines will have the same threading sequence.
Just a hint: be sure to RAISE the presser foot BEFORE threading the upper thread so the tension disk will allow the thread to seat properly.
Video Demonstration of vintage Montgomery Wards Sewing Machine built in...
Dec 05, 2015 | Montgomery Ward Sewing Machines
I need a manual for Montgomery Ward sewing machine model #uht j1914
I could not find one for your specific model but I did a similar one here:
Montgomery Wards Sewing Machine Instruction and Service Manuals
#51 should be a close enough match for you to discovery the different functions you are looking for
Jul 16, 2015 | Montgomery Ward Sewing Machines
I have old montgomery ward sewing machine model UHT J1264 and it is stuck in reverse. I don't know where the switch is. Help?
The reverse button is on the frount in the center of the knob to the right of the machine, if it only goes in reverse the button is stuck pressed in. I have the same machine but am needing parts to mine, if you ever want to sell it please contact me
Hope this helps
Mandy
malenia92@att.net
Aug 13, 2010 | Sewing Machines
Help with an older sewing machine
There are lots of men who sew...it is not gender specific.
Perhaps this will help--unfortunately not free:
Wards 1984 Instruction Manual
Montgomery Ward did not make their own machines, so it was most likely manufactured by a sewing machine company with Montgomery Ward's name on it.
However, most machines thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading the top thread--this allows the thread to seat in the tension disk. Set the top tension to about the midway point to start and then tweak from there.
threading older sewing machine Google Search
Understanding Thread Tension Threads
Bobbin tension is usually the last thing to try to adjust...be sure to mark the screw setting BEFORE making any adjustment...
Bobbin Tension How and Why Tension is Adjusted
Needles are probably the least expensive resolution to a lot of sewing machine problems--change them often!!! About every 8 hours of sewing, and be sure to use a needle that is compatible with the thread and fabric. Be sure to install the needle with the flat part facing the correct direction. Most machines have the flat part facing the back of the machine, however, some machines with the bobbin loading from the side will have the flat part of the needle facing the harp (throat) of the machine. AVOID old or bargain bin threads! Use fresh, good quality sewing machine thread (generally, Coats & Clark is not one of them...)
All About Needles
May 13, 2017 | Singer 7422
Sewing Machines Logo
81 people viewed this question
Top Montgomery Ward Sewing Machines Experts
D. E. Hev
DavidinClt
Level 1 Expert
Are you a Montgomery Ward Sewing Machine Expert? Answer questions, earn points and help others
