I am trying to connect a BT internet booster which is suitable for all routers via wps but my EE router doesn't have a button I donT own a computer only iPad how can I connect device please
SOURCE: how to connect linksys router with aztech adsl modem
1-Go to ip address of aztech modem 192.168.1.1
2-Default usermname and password is "admin"
3-Go to quickstart-> Turn off firewall (uncheck)
4-Save changes
5-Connect modem to router's wan port
6-Go to router setup , and select connection type as dynamic ip.
7-Save and restart modem
Solution 2
1-Go to modem quickstart
2-Select connection type as bridge, save changes
3-Go to router's setup, select connection type as Ppoe, give ur username and password provided by internet provider
4-Save changes
5-Restart modem and router
Posted on Jun 06, 2008
SOURCE: Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
Posted on Oct 06, 2008
  • 33 Answers
SOURCE: my linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Posted on Jan 25, 2009
  • 202 Answers
SOURCE: Cannot connect to wireless router with WPS-PSK encryption
Don't use the passphrase. Go into the configuration of the Netgear device to where your set the security. The passphrase will generate 4 codes. You choose which one you want to use. I would copy all four codes and paste them into a spreadsheet or text file and save that to a memory stick or other suitable portable memory. Move that to the laptop causing the issue and paste the code into appropriate field. Save the configuration and you should be set.
I have worked with some devices that do not generate and save the codes correctly. Manually entering them has resolved the issues I had.
Good Luck, and please let me know how this works out for you.
~ Spoem
Posted on Apr 27, 2009
enoch_cog80
  • 33 Answers
SOURCE: Suddenly no connection to the internet via wirelss. LAN via the same router works fine.
its the problem of your service provider.... contact your service provider
Posted on May 23, 2009
102 stc i can`t use the phone. light for the phone on router is red this happened after reseting the router
Did you change the password on the router? Did you WPS to connect the phone to the router? If so, use WPS again.. that's where you press the WPS button on the router and tell the phone to connect via WPS at about the same time.
Jan 13, 2018 | The Computers & Internet
Where is the wps pin on a Samsung direct w8c48x printer
It relies on the WPS button on your router. Get to the Searching for WiFi on the printer then push WPS button on router. After a little delay the printer should say it has connected to network. If not, use the function that connects via the router password entered directly.
Good luck and please rate 4 stars if answer is helpful.
Oct 17, 2017 | Samsung Computers & Internet
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
Can a WiFi repeater with WPS connect to a Wireless router without WPS ? I can't seem to get them to connect to each other via WiFi
WPS only works with client Wi-Fi devices that have a WPS button.
Your router does not have it, so it does not work.
Jan 06, 2015 | Computers & Internet
Why is my WPS button blinking?
A blinking WPS on the router usually means it is actively waiting for a device to connect. For security reasons, it is best to set a time limit for how long WPS pairing can remain active in the router, or to turn WPS off completely and connect only with a standard WPA/WPA2 security key.
Once a device is connected via WPS, it is as secure as if it was connected with a standard security key. WPS is only there as a way to make connecting to routers easier with a shorter password that is supposed to only work for short time while WPS pairing is enabled. ALL OTHER TIMES, WPS SHOULD BE TURNED OFF!
Oct 08, 2014 | Computers & Internet
I got a Netgear WNCE2001 today. My router is a Verizon router. (The one with the WPS button on the front.) The security password is in WEP. When I try to connect it with WPS, the light on the WNCE2001 just...
which light is blinking ?
may be this help you ?
2. Select a radio button.
• Push and Connect (recommended). Either click the button or press the WPS
button on the rear panel of the Internet adapter.
• PIN Number. Select the radio button and a PIN displays.
The Internet adapter tries to join the wireless network for 2 minutes if you are using Push
'N' Connect, or 4 minutes if you are using a PIN.
3. Go to the router.
• If you are using Push 'N' Connect, press the router's WPS button.
• If you are using a PIN, log in to the router and type the PIN from your Internet adapter
in its WPS screen.
4. Go back to the computer that is connected to the Internet adapter, and make sure that you
are connected to the wireless network.
• When WPS is running, the WLAN LED blinks, alternating between green and amber.
• If the computer does not to connect with WPS, the WLAN LED is solid red for 5
seconds.
• If the computer does connect using WPS, the WLAN LED is solid green for 5 seconds
Then the WLAN LED returns to indicating a wireless signal.
Feb 12, 2014 | NetGear Computers & Internet
Where is the wps button
https://www.manualslib.com/manual/382487/D-Link-Dcs-932l.html?page=13
Apr 08, 2017 | Motorola Computers & Internet
I am trying to hook up a netgear universaL WIFI INTERNET ADAPTER to my tv and it says to push the WPS button on my router and i dont know what to push
The dlink dir 615 wireless router hasnt got wps. So its no good trying to connect it via that way you can only do it via wep or wapor wap2 here is a link to the manual for your router http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Mar 11, 2011 | D-Link DIR-615 Wireless Router
Computers & Internet Logo
David Payne
David Payne
