Question about Inverter Electronics - Others
I have got 1000w inverter put connection on wrong way round big spark inverter now doesnt work are they any fuses inside
  • Pierre Curtis Dec 07, 2016
    Hi keith bone, I want to help you with your question, but I need more information from you. Can you please add inverter Make & Model in the comment box?
  • keith bone
    keith bone Dec 12, 2016
    cant find any numbers only that it is pure sine wave inverter
  • 1,162 Answers
Probably have but more likely a diode or two has blown also.
Posted on Jul 19, 2017
2 Suggested Answers
  • 10291 Answers
SOURCE: Just connected my durite 1000w inverter to battery wrongly got a big spark now will not work
Check the fuses . Look inside for a fuse on the circuit board. There may be some burned up components inside too.
Posted on Jan 27, 2015
My 1000w eliminator inverter only puts out 100w. overloads and goes to Fault
Check your battery voltage when running the inverter. At 100W, the voltage may drop several millivolts maximum, initially and will slowly drop. At 100W, the inverter may draw 15 to 20 amps from the battery. At 1000W, the inverter will draw upwards of 100A which is very hard for most batteries to provide for very long. I have a 5000W inverter connected to a 12V, 830AH battery bank. At 600W output, the inverter draws 70A. At 1500W, it draws almost 150A. At 600W output the battery voltage will drop almost 2 volts over 8 hours of operation. At 1500W, I would get maybe 5 hours, but I have never run a load like this for any length of time.
If you put a 100W load on the battery and the voltage drops 2 volts very quickly, then the battery is shot.
Jan 11, 2018 | Inverter Electronics - Others
Jan 26, 2015 | Electronics - Others
The blue inverter power is 1000w It can't genrate a water pump 300w Or 100w why
to me the watt realy dosent matter in this situation.what you have to do is that you connect the water pump to a breaker fuse which will control the load.not all inverters releases much current to pumping machings to work and even sometimes it ends up burning the inverter
Oct 12, 2012 | Heating & Cooling
My inverter keep blowing 40 amp fuses without load
Hi Trevor,
A 1000W can barely supply 5A at 220V, less than 10A at 110V. So if a 40A fuse blows, there is a serious problem and you should not attempt to use this unit after it has been checked by a qualified person. Please be careful!
Nov 20, 2011 | Sunforce 1000 Watt Pure Sine Wave Inverter...
I inadvertently reversed the DC leads (pos. to neg. and neg. to pos) on the battery. There was a spark and now the unit (1000W continuous) is completely dead. Is it easily repairable or should I just get...
You didn't indicate what model inverter you have. Most have either a fuse or a circuit breaker. You should be able to replace the fuse or reset the breaker. These are designed to protect the secondary side from overloading the inverter, so they might not help with the reversed leads.If you are connecting this directly to the battery, you should install a fuse in the positive wire before connecting it to the battery.
Nov 23, 2010 | Victor Electronics - Others
My 400 watt inverter will not charge my laptop the fuse keeps blowing?
Your laptop PS has big condensers in the input. Even supplied by mains through 6A quick fuse or automatic breaker it will drop first time, but may hold the second. Your inverter may be has fast fuse 2 - 5 A. If not so fast it may carry the initial load.
Hint: If you are not "both left handed" you can connect  20 - 200 Ohm (2 - 10 W) resistor in series to your Laptop Power Supply. After the initial start of the inverter you can shorten the resistor by a 3 - 5 A switch.
Jul 01, 2010 | Vector 1000w Power Inverter
What is wrong with my 1000w sony xplod amp?
need repairs on the inside usually when u see that fuse melt something else probably melted on the inside. something is grounding out the amp on the inside . get it checked
Jun 05, 2010 | Car Audio & Video
Power going up and down
An incandescent lamp that is cold takes approximately 10 times the running current initially. The inverter MAY not be able to start the 500 watt lamp if its protection circuits sense the very low starting resistance of the lamp.
Test the inverter on some other device first.
Jul 26, 2009 | Coleman Cable Power Inverter PMP1200
My Sanyo 1000W microwave is shooting sparks!!!
you need to replace the cavity cover "the cardboard like",the antenna bearing set "the gun barrel like" and the gear motor.If the "gun barrel like" is stuck up because the gear motor is not rotating excessive heat will occur inside the microwave thus burning the cavity cover.
Mar 20, 2009 | Sanyo EM-A5200SW Microwave Oven
Inverter not working
Inverter is charging battery but if I switch on load button , It starts making noise loudly. can you suggest solution
Feb 15, 2009 | Black & Decker 750w Power Inverter
Electronics - Others Logo
693 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Clint Millett
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
