Question about Sewing Machines
The reverse stitch button is stuck in (or broken) and machine only sews in reverse. Can this be repaired?
When pushing the reverse button there is no tension. It pushes easily and machine is stuck in the reverse stitch mode.
    Top Expert:
  • Sewing Machines Master
  • 8,204 Answers
Have you followed your user guide instructions re making needed setting adjustments back to a sewing mode? Have you checked the guide for instructions on 'resetting to factory default' so that you can reprogramme?
If the above doesn't help, have you tried a 'shock reboot'? Start by turning on machine on and let it sit for a few minutes then without turning it off, pull the power plug from the electrical outlet. Wait five minutes then reconnect and turn on your machine - it should have defaulted back to factory settings. You'll lose your saved stitches but your machine should function properly again.
If that doesn't get your machine sewing forward, something the wee man did snapped something inside the machine (usually a gear and the things are easier to 'snap' than people realise) and it's time for a trip to the repair tech...,,THIS IS ALL I COULD FIND ON THE this manual...
Posted on Dec 06, 2016
My heavy duty Singer sewing machine is stuck in reverse. How do I fix it?
If this machine has a mechanical lever or button it may be internal parts have broken and need to be replaced. this is a common issue with lots of machines. The machine breaks when in reverse and will only sew in reverse. Please have a professional look at the machine and make a repair if necessary.
Embroidery Services
San Diego, CA
Sep 13, 2017 | Singer Sewing Machines
Viking/Husqvarna 5710 sewing machine is stuck in reverse. Reverse button isn't stuck, but doesn't pop out by itself anymore. Stitch dial isn't in between stitches. Put wd40 in the insides, didn't help
Uh-oh. Don't use WD-40 on your machine... WD-40 becomes sticky with time and will seize the mechanics...
Wondering if there is a spring under the R button that perhaps is broken or collapsed.
Apr 27, 2017 | Sewing Machines
I have a Montgomery Ward model 1934 sewing machine. The reverse button has no tension and the machine is stuck in reverse stitch mode. Can this be repaired?
You may want to take it for service. Could be the machine has seized with the reverse button stuck. May need to be disassembled.
Dec 06, 2016 | Montgomery Ward Sewing Machines
Where is reverse button
Depends on the make & model of your machine. Would be best to consult the owner's manual. Mechanical and computerized machines also vary. Mechanical machines usually have a stitch length lever that, when pushed all the way up, will reverse stitch, or there is a button usually marked with an R or an arrow. Computerized machines usually have a button marked by a U-shaped arrow.
Of course, if you have a vintage sewing machine, it may not even have a reverse stitch. Instead, to sew in reverse, one would have to sink the needle into the fabric, raise the presser foot and swivel the fabric 180 degrees, drop the presser foot and stitch.
To find a copy of the owner's manual, search the internet for:
Manufacturer + Model + the word "Manual"
sewing machine reverse Google Search
Dec 04, 2015 | Sewing Machines
My riccar 707 is stuck in reverse. stitching,what is the. problem.?
Most machines have a button that is on the front of the machine. It is located on the front with machine with the stitch selections. The button is pushed in. Push the center button again and if that doesn't work, push the outer edge of the button and it will release.
Mar 02, 2015 | Riccar Sewing Machines
My reverse button is stuck and the lights on the stitch panel keep flashing, how do I fix it?
Meybe if you reformulate your questin telling WHAT brans and model of sewing machine are you using, someone might give you a straight answer
Feb 06, 2015 | Sewing Machines
Reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
Jun 03, 2008 | Husqvarna Viking 1
Reverse only?
I too just aquired a husqvarna viking 6030 that was stuck in straight-stitch reverse. No forward, no zig zag, no button hole, no cam stitches. I also suspected a broken spring, since the reverse button was slack and had no resistance. But after inspecting every moving part, I realized it was just stuck from many years of non-use. I finally got it free today! I had used some Tri-Flow oil and applied it sparingly to all moving points (but not belts or motor). I exercised all the buttons and like another poster (either here or elsewhere, not sure) I used my hair dryer to apply heat to the inside of the machine through the cam slot. After you remove the white cover on back of machine that holds the two spool spindles, you will see a formed aluminum part just behind the reverse dial that has a rounded-pointed protrusion which sort of looks like a fat flat head screwdriver. It is supposed to travel in an up-down motion when reverse button is pressed. I used a flat head driver to coax its movement, and once it began moving, I continued with heat and drops of oil. Good luck.
Nov 11, 2007 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
