Question about HTC P3450 Touch Black Unlocked Smartphone (European Version)
Red light is on, won't take a charge, screen won't lite up, won't communicate through it's cradle to my pc. Help
  • 3 Answers
Check and make sure the contacts are clean on the battery terminals, the terminals on the phone and also that the charger terminal and where the charger terminal connects to the phone are clean. Did you drop the phone? Something could be broken or could have come loose. Did you drop it in water? Corrosion could be preventing power to get through phone and/or to the battery.
Lastly, battery could be damaged, defective or just plain dead. If you know someone that has a similar phone (or the store you bought it from) see if phone will power up and accept a charge. If that works, it is your battery.
Posted on Jul 20, 2009
  • 11,896 Answers
Check to see if the prongs on cradle are sending out power. You can do this with a test light or multi-tester.
You can also try plugging in without the cradle if you have a way. If results are the same, then the battery may need to be replaced
I have a Nintendo Ds lite, I try turning the device on and the screen won't lite. It charges indicated by the light. Help
The internal screen flex might have disconnected or got damaged. You might need to get open the DS by a qualifiad person as if you open it foir yourself, might get more damaged
Jun 24, 2013 | Video Game Consoles & Games
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
DS Lite screen won't light up
your battery is very low. Charge the battery for 3 hours. you can still play games, while it charges.
Jan 14, 2013 | Nintendo DS Lite Console
I have a logitech cordless mouse that does not charge when placed
either ur cradle or ur battery hav been damaged...
try changin it...
Mar 11, 2010 | Computers & Internet
Battery in cradle don't charge
Two reasons. Either the battery is dead or the cradel's charging circuit is faulty. But the red light shows that the cradle is fine. SO, the axe falls on the battery.
Sep 19, 2009 | Casio Exilim EX-S880 Digital Camera
Reset button won't work on dell axim x51v
to wlumbria... hey listenup... if ur connecting ur pocket pc to the cradle it is not only used for the flow of data bt it also charges ur pocket pc... bt the chargin is quite slow  it will keep on showing  the red lite as compare to an charger it will charge fast and the red lite will turn green... so wht i suggest charge it with a charger not with a cradel if stil it doesnt wrk try changing the battery...!!!
Aug 21, 2008 | Computers & Internet
H6315
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
Dec 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
Red Light
try to charge ur phone on other cradle if its getting charged then problem with the cradle or else try another battery in ur phone or contact service centre for more support good luck
Oct 11, 2007 | HP iPAQ hw6515 Pocket PC
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
HTC  P3450 Touch  Black Unlocked Smartphone (European Version) Logo
484 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
