Error code 400?? - Office Equipment & Supplies
What is the error code sc400 in ricoh c2030 printer copiers
Ricoh Aficio MPC2030 Code: 400
Description
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400". The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than the value (default: 4.5V) specified with SP3324-005 or less than the value (default: 3.5V) specified with SP3324-006.
Causes
• Dirty or defective ID sensor • Defective ID sensor shutter
http://www.printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC2030&code=400
Sep 11, 2016 | Ricoh Office Equipment & Supplies
Ricoh sp C221SF Error code Sc 400
The board that controls it. Probably the IOB. Typically, the code is cause by a dirty ID sensor.
Oct 04, 2014 | Ricoh SP C221SF Aficio Printer
Reset the error code on a precor elliptical
Not familiar with an error 400 - and error 40 is an elevation error - it needs to be addressed(fixed) cannot really be reset otherwise. Check connections and fuses first. If it was recently put together, make sure the data cable was not pinched. If it is battery operated, an error 40 can occur when the battery is low.
Oct 02, 2014 | Precor EFX 546i Elliptical Version 4
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Canon ir 400 error code 051
I m E220 Error how to clear the error of Ir 400
Jul 29, 2011 | Canon imageRUNNER 400S Copier
Invalid command, line 01 code 400
Mornach 9825 printer is error "Invalid Command! Line 01 Code 400 ".How issue this error.
Apr 16, 2011 | Monarch Paxar 9855 Printer
Error code 400
If it is system error code.
System error code 400 means "The thread is already in background processing mode." This error code may also display as "ERROR_THREAD_MODE_ALREADY_BACKGROUND" or as the value 0x190.
Try this,
Clean your system using any commercial or free system utilities like CCleaner(free), and cleanup the system registry too.
Jul 08, 2010 | Microsoft Windows XP Home Edition
I work in a lab and we use a monarch paxar 9825 label printer and this morning it has an error code 400. What is this error code?
These types of errors are data errors. If you post your datastream, I may be able to tell you where the error is at.
Dec 11, 2008 | Paxar Monarch 9825 Thermal Label Printer
Hi I bought my fine drive 400 in Ebay. error code: 420-01-0x08
this may be due to corrupted firmware, I have posted the files to fix this:
here is the link to the instructions and install data.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
Feb 13, 2008 | Fine Digital FineDrive 400 GPS Receiver
23 people viewed this question
jasbo
jasbo
