Question about Home
Water temp coming out of shower is on a set temp I would like it hotter
  • 10865 Answers
SOURCE: shower gets hotter or colder when toilet is flushed.
The problem you have is so common. It is caused by the fact that all of the water lines in the house are the same size, usually 1/2" copper tubing. The only way to eliminate this problem is to use 3/4" tubing as the main lines and branch off with 1/2" near each faucet. Not an inexpensive fix. In the short run tell everyone not to flush the toilet when the shower is in use.
Posted on May 03, 2009
snap101
  • 117 Answers
SOURCE: The water coming out in the shower from a
pull the handle off and there is a black dial you can pull out and readjust on the shaft of the cartridge that will allow you to have cooler and hotter settings. it's black plastic and has little splines on it . the more you go one way the hotter it gets and the same the other way gets cooler
Posted on Jul 29, 2009
  • 8 Answers
SOURCE: How can I adjust the shower knob to produce hotter
Should be able to adjust clockwise or counter clockwise to adjust the temp. You said that the temp used to be hotter. Check the temp setting on your water heater. Did you replace your old water heater? Hope this helps.
Posted on Mar 11, 2010
ExHandyman
  • 86 Answers
SOURCE: I have a pioneer shower valve that has pressure problem
The way anti-scald valves work is there is a slide tube inside the faucet which requires pressure from both hot and cold or else it will cut off the flow. As for temperature adjust I do not believe there is an adjustment screw but more so there are these white plastic toothed stop rings which prevent the handle from turning 360 degrees. When your adjust the stop ring, it adjusts how much hot water is allowed to mix with the cold water. My wife likes her showers a lot hotter than I, so I gave a good allowance with the stop ring. The "adjustment screws" which you are viewing are not for adjustment of temperature, they are remote cut-off screws to stop the water entirely to change the washers in the unit if needed. SO open those all the way and leave them open. Think of them as not having to go all the way into the basement to shut off the water supply just to change a few washers.
Posted on Mar 20, 2010
Testimonial: "Thank you exHandyman.... it worked "
  • 349 Answers
SOURCE: & Single Handle Shower Faucet : how to adjust to get hotter water...
First step remove handle and behind it there is a dial that looks like a gear. Mark where it is and remove it and put back in about a 1/4 to 1/8 turn counter clockwise to increase to hotter temp.
These faucets are equiped with anti scald setting's to protect the public and preset for this reason.
Posted on May 20, 2010
I have a moen shower faucet where the water mixture keeps getting hotter with very little cold coming through. the temp must be set nearly all the way to cold to prevent scalding.
Sounds like a pressure-balance shower valve. The pressure balance cylinder is stuck. With water off, remove knob and trim plate. Remove pressure balance cylinder (horizontal). May be hard to get out. Use emory paper to clean up cylinder and smooth it so it moves freely. Reassemble and you'll be happy.
May 28, 2017 | Moen Home
Why does the water temp delivered from two Visu-temp valves in back to back bathrooms turn lukewarm after about 4 minutes.
personally I would change the temp setting to hotter water .isn't that why we have a cold water valve also to mix you will use less hot in the long run
Jan 15, 2015 | Water Water Heaters
Adjusting Apollo hot water tank
I am not sure what you are asking, But i am going to assume that you want to know about changing the Temp on the heater for inside the house.
If the floor heat was installed properly than it should have a temperture manifold or adjustable thermostat for seperate heating.
You need to find the thermostat or manifold for the garage heat and set it at what ever temp you want the garage to stay at.
Then you can change the A B C knob to a higher setting A is cold B is warm ac is hot. So Increase your temp setting on the heater and this will increase your house water temp for hotter showers and faucet temps. However, they recommend not setting the temp above 120 degrees to prevent severe burns.
If you have a newer home increasing the Hot water heater temp setting may not change the temp at the shower or faucets if you have scald guard faucets installed in the house. This will require adjusting the scald guard valves on each faucet.
I recommend using a candy thermometer or digital thermometer to check the faucet and shower Temp prior to using them and make sure that you inform everyone in the house after you change the temp so that no one gets scalded.
I hope this answers you question, feel free to contact me if you need more help!
DR Wilkins
Oct 15, 2013 | Water Heaters
I am trying to service a symmons Safetymix Visu-temp 4-500VT/ It only gets tepid water temp. I have not worked on one of these before, So am not familiar With the breakdown or servicing. Can you tell me...
you should be able to look online and copy manuel....but most systems have a temp limiter under handle...plumber probably did not set far enough to left for hotter temps...after you pull handle you should see a limiter pull and turn all the way left and reset....you should now be ok...good luck..
Feb 23, 2011 | Dmm Symmons Safetymix Visu Temp shower...
Can I adjust the hot water temp if I have a Posi-temp faucet?
should have a gearlike part under handle that can be adjusted so as to allow the handle to rotate to more hotter (left) or warmer
Dec 08, 2010 | Moen Posi-Temp Single HandleTub And Shower...
May 17, 2010 | Delta & Single Handle Shower Faucet
How can I adjust the shower knob to produce hotter water then it does now. It used to be hotter. Taking the knob off reveals a white piece of plastic with a colder to hotter temp. gauge. How can I adjust...
Mar 07, 2010 | Home
The water coming out in the shower from a Hansgrohe ThermoBalance I control is a little too hot on the coolest setting.When the center temperature control is turned to the clockwise stop position which...
Jul 17, 2009 | Hansgrohe Home
Installing a Mixer Shower from a Combi Boiler.
hi there, your boiler will perfectly match the mira excel ( a great choice i might add) a 24cdi will give about 9.8 litres a minute flow rate hot water.
The mira excel is suitable for any plumbing set up and there installation instruction are very well laid out & their helpline is fantastic.
The hot water will fluctuate accordingly to the time of year as the cold water temp coming into the property will vary. but the boiler will modulate to compensate.So in brief in the summer you will notice it hotter than you would in the winter, this has nothing to do with the boiler just the incoming temp of the cold water.
Kindly
Richie
Dec 15, 2008 | Home
Home Logo
90 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
