Question about Whirlpool Refrigerators
How do I remove the plastic cover to remove the control board on the whirlpool w rf40ix without breaking the cover?
  • Whirlpool Master
  • 3,097 Answers
Although this is not a straight answer, it might head you in the right direction.
Type in "SearsPartsDirect " to you search engine, and you will get Sears.
Type in your complete model number and you will get pictures of all parts of your machine.
Select the one that you need, and see how that part fastens to the control board.
(When I am faced with a cover that has been glued or "plastic welded" in place, I will occasionally use a Dremel tool and cut the cover off, then reglue it back on with epoxy cement. This is when I have nothing to loose, a part is already headed for the trash pile.)
God bless your efforts.
Posted on Dec 06, 2016
Testimonial: "Thanks David"
How to remove panels around the ice maker on whirlpool WRF989SADH00 French door refrig. Need to see if ice maker is overflowing
purchase the service manual. or you could be investigative and find where the clips are and pop them without breaking them. good luck.
Jan 02, 2015 | Whirlpool Refrigerators
Tip
KitchenAid, Whirlpool side by side refrigerator remove the main control board...
Electrical Shock Hazard
Connect green ground wire to ground
screw.
Failure to do so can result in death or
electrical shock.
REASSEMBLY NOTE: Be sure to reconnect
the green ground wires; one to the compressor
terminal, and the other to the chassis (see the
previous steps).
7. To remove the main control board assembly:
a) Remove the unit compartment cover
b) Remove the two hex-head screws from
the rear of the main control board assembly
enclosure, and position it so
you can access the board.
c) Remove the wire connectors from the
main control board assembly.
KitchenAid, Whirlpool side by side refrigerator Component Location and removing cover
http://www.fixya.com/support/r5759997-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method A
http://www.fixya.com/support/r5760017-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method B
http://www.fixya.com/support/r5760029-kitchenaid_whirlpool_side_side
on Aug 27, 2010 | Refrigerators
Jet arms will not turn
check if its dead then the power coming into the unit is bad or the fuse inside on the control board has blown.
check the power at the dishwasher and if all is well then open the door, remove all the screws from around the edge, raise the inside panel, swap the fuse thats on the control board
If the control panel is not lit at all and the dishwasher doesn't function either then you will have to check the fuse. The fuse is on the control board. It is a white flat plastic fuse that is on the front of the control board.Remove the screws from the inner door. There should be about eight or so screws that need to be removed from the door we it is opened.
After those screws a removed you can pull off the inner and outer door to expose the control board in the top portion of the door. It is usually in a black plastic cover that protects the board. You will need to depress the clips on the black plastic cover on either side to release the cover. Once the cover is off you will see the control board and fuse attached to the control board.
If you have a meter you can check the fuse with continuity. First unplug or turn the circuit to the machine off. Then take the wires off the fuse and put the leads from the meter onto the terminals of the fuse. And then set your meter to ohms or continuity. You should read 0 ohms or a tone with continuity. If the fuse is good and has continuity then you need to replace the main control board.If the fuse is bad you will have to change it.
Jun 26, 2014 | Whirlpool DU930 Built-in Dishwasher
How do i remove front panel on a Whirlpool wfw96heac
I have a whirpool duet qnd to get the front panel off you have to take out the soap drawer and there is a bolt there that has to come out.
also I had to pry off the trim piece around the control panel to get to the rest of the bolts. I did it carefully and it came off without breaking.
May 03, 2014 | Whirlpool WFW96HEAC R 4.3 cu. ft. Duet...
What does F11 mean?
F11 means that the circuit board at the top of the machine (CCU) is not communicating with the circuit board at the bottom of the machine (MCU). If you're getting an F11 code you may also get a FdL code (communication from the door lock to the CCU), in either case the problem is with poor quality control by whirlpool. On the CCU board there are what's called cold solder joints at the point where the relays and spade connectors connect to the circuit board. You'll need to remove the board and have those solder joints touched-up. You may break some plastic tabs removing the circuit board, that's because whirlpool used the cheapest plastic they could find. If you can't do the job yourself, take the board along with this response to a good appliance repair place. Good luck.
Nov 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet washing machine and I put wash in and water started coming in and then it went to F
If you're getting FdL or F11 codes flashing at you, the problem is in the circuit board, inside at the top back of the machine. Whirlpool seems to have poor quality control on this item. The problem is cold solder joints where the different components attach to the circuit board. The joints where the spade connectors and the relays connect to the board are thicker joints and whirlpool didn't get enough solder to flow into those joints. You can remove the board (remember where the wires go) and touchup these joints yourself or remove the board and take it to a competent appliance/tv type repair shop and they should be able to do the job. Also, the plastic enclosure for the circuit board is pretty crappy (made from the wrong grade plastic) so little tabs may break, be careful.
Oct 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Refrigerator side lights quit working bulbs are new
your control board in the lower rear of the unit is defective,a tell-tale sign of this sometimes is, if you can hear a buzzing/chattering sound and the refrigerator lights strobe dimly and the temp set and read-out in the refrigerator is not lit,the control board is located after you remove the rear lower cover on the back side of the unit and on the left inside wall you will see it in a plastic box,remove the screws that secure the box and then remove plastic top cover and there will be 3 wiring harnesses,unplug them,replace the control board and reverse procedure to reinstall
Jan 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool custom series frig & the bulb has gone out. After switching it with 2 new bulbs with no results, I wonder if there is an electrical problem? Additionally, what appears to me to be...
Yes KariAnn,
I have replaced 3 of these this week already, its the control box,lower left corner inside white plastic box, when light bulbs blow out it surges& the control board is ruined, its quite common, replace it with a new board no need to replace the cover or box with a new one, go to appliance parts pros or call 1-877-477-7278, the cost will be about $85.00 with shipping included, UNPLUG REFRIGE FIRST, and remove control board(2screws) on back of refrige, take off plastic cover and unplug 3 wire harnesses and install new board put cover back on and its good to go......if you have any other questions I'm at dmftrucker@yahoo or 24/7 Appliance Service (608)214-5632....Regards Daniel
Oct 08, 2009 | Whirlpool Refrigerators
Speedometer needle is stuck under its peg.
Bummer. Unless you know how to remove the glass/ plastic cover, which you intern have to successfully remove, and re-install the dash board without breaking the plastic clips, you should go to a professional. Sorry buddy.
Sep 27, 2009 | 2001 Dodge Stratus
Speaker Removal
the plastic piece should just come right off
Apr 12, 2009 | Car Audio & Video
Refrigerators Logo
32 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
