Question about Epson Office Equipment & Supplies
I have an EPSON WF-3520 and suddenly started doing then reboots. Once startup is complete, a beep sounds and restarts. This is done continuously as long as a supply voltage.
  • 3 Answers
SOURCE: intermittent shut down
My Dell 5150 Dimension P4 3.0 Ghz was doing the exact same thing. The problem is very common with this model. No PC clinic I took to can solve my problem. They said it's MB, it is not! The problem is due to insufficient cooling from the factory 120MM fan which draws little air. Here is how I fix it. Remove the plastic shroud that holds the heatsink by losening the 2 screws and unplug the fan wire from the MB. It should come off easily unless your heat sink compound has hardened. Thoroughly clean the Al heatsink/fan with a long bristals brush.( Optional: If you want, remove heatsink compound from cpu and HS and apply a thin even layer of Artic silver with your index finger covered with siran wrap). Buy an 80mm quiet fan (Sunnon or any good brand)with a large 4 pin connector and get 4X 1.5" 1/8' self tapping screws. Mount the fan so the bottom just clears the HS on the MB. Direction of air flow is away from HS. Look for the arrow on the fan If the screws won't tap into the al HS, squeeze the al plates closer. Don't over tighten the screws, it's al, it is soft. Install back hs/FAN , tighten the two green screws and clean inside of PC with brush on the outside of your house. Plug in the fans power. Fire it up leave in on for a week, your HS should be ice cold. Another solution is buy a newer Pentium dua1 core that uses 65W instead of the 95W chip from Dell. A good one is E5200 at C$80. In this case ,you dont't need the extra fan. To upgrade your PC with a non Dell MB is possible. Get a Zotac ITX MB 170MMX170MM . Some grinding maybe needed. One good one is Zotac NF610I-D-E MINI-ITX LGA775 GeForce 7050 DDR2 1PCI-E1 2SATA2 RAID LAN VGA Motherboard at C$65
Posted on Jun 05, 2009
  • 733 Answers
SOURCE: steady single beep at startup
if you want to know what it mean's check here
Posted on Dec 03, 2009
  • 190 Answers
SOURCE: Acer Laptop Aspire 5315 Continuous Beep on Start Up
its either there is a stucked key on your keyboard or you have a bad ram (memory card).
Posted on Jun 11, 2010
SOURCE: I have a tk-390 portable radio and it continues to
I am having the same problem. Does anyone out there have a solution?
Posted on Dec 07, 2010
  • 998 Answers
SOURCE: Laptop beeps continuously on startup until "fn"
Number of Beeps: Failure Coverage 1) BIOS ROM checksum inprogress or failure. BIOS Chip 2) No RAM Detected No Memory Detected NoMemory Detected 3) Chipset Error (North and South Bridge Chipset,DMA/IMR/Timer Error for Intel platform); Chipset Error Motherboard FailureTime-Of-Day Clock test failure. Gate A20 Failure Super I/O Chip Failure KeyboardController Test Failure Motherboard Failure 4 )RAM Read/Write Failure Memory Failure 5 )RTC Power Fail. COMS Battery Failure 6 )Video BIOS Test Failure Video Card Failure 7 )CPU Cache test failure CPU Failure 8 )LCD LCD Failure
Posted on Apr 21, 2011
Epson WF-2530 keeps restarting.
I have the same thing. I suspect they have released a messed up Firmware :-(
I am trying to find a key combination at startup to see if that does something, the printer is otherwise completely unresponsive.
Dec 07, 2016 | Epson WorkForce WF-2530
Epson WF-3529 printer seems to feed two sheets at a time when printing
In some countries, due to moisture in the air, during some weather conditions, this is common.
Fan paper well before loading in the tray.
Also depends on the type of paper.
Use manufacturer recommended grade. gsm80 in most cases.
Sep 06, 2016 | Epson WorkForce WF-3520 All-in-One Inkjet...
Purchased the ciss ink system for my epson wf-3540. the ink tubing keeps getting pinched and the ink isn't flowing continuously.
I installed a CISS system in my WF-3640 which is very similar to the 3520. I just leave the top open and put a small piece of white eraser in the slot where the cover peg would go into. That way the printer thinks the top is closed. Yo can print, scan, copy, fax, etc., with the top open.
Oct 05, 2015 | Epson WorkForce WF-3540 All-in-One InkJet...
Why does ink cartridge not push down
Epson WorkForce WF 3520 All in One Printer
1. Are you sure you have the correct model ink cartridge?
2. Did you remove the yellow strip as shown in the illustration at the link above?
May 02, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Paper Jam Error but there is no paper jammed. False error message
I know it sounds silly but when my Brother All in one does this the trick is to pull the main supply cord, count 10 and reconnect(Or turn off at the wall) The brain then reboots and all is well.
Feb 23, 2015 | Epson WorkForce WF-3520 All-in-One Inkjet...
Wf-3520 scanner is not working
First check its power is on then check its data cable connectivty with pc.
Sep 27, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
3520 instructions
Go to epson's web site and check for driver updates.
Mar 02, 2018 | Office Equipment & Supplies
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
