Question about Garden
Looking for a replacement gun for a workzone pressure washer help!!!!!
4 Suggested Answers
  • 173 Answers
SOURCE: Pressure Nozzle (Gun)
Posted on Jul 08, 2009
  • 363 Answers
SOURCE: Ineed to replace the hose on my champion cpw1750
If the hose is screwed into the gun then you are lucky because you only have to replace the hose, but if the hose is clamped inside of the hose then you have to replace both the hose and the gun
Posted on Aug 01, 2009
  • 21 Answers
SOURCE: power washer starts no problem
the tip could be plugged up
Posted on Aug 29, 2010
I need a workzone 2.2 pressure washer manual
Goggle it manuel for ---------
Jul 23, 2017 | Garden
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Need instructions for Workzone staple gun
    insert staples , point away from living things (dogs,cats,humans etc.) and squeeze the lever to discharge staples.
    Mar 24, 2013 | Tools & Hardware - Others
    Engine runs , not getting any water flow when trigger pressed.
    Disconnect hoses.
    Look for kink in water hose.
    Check incoming water connection for filter washer
    Replace filter washer
    If you don't have a filter washer, put one in.
    Hook up water, and turn on
    Water should come out other side of pump.
    Turn on machine.
    Do you get pressured water out of pump.
    If no pressure, then pump is suspect
    Hook up washer hose without gun
    Does pressure come out of washer hose
    Finally, the gun trigger may be bad.
    We had to buy guns now and then.
    Search for pressure washer guns
    Following link shows guns we used:
    Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
    My Honda GCV160 Pressure washer runs great, but isn't creating any pressure out of the nozzle. Not even a drop out of the wand. Its been on hiatus while I've been recovering from an injury for 3mos. It...
    Take hose and gun off pump.
    Start engine.
    See if pressure comes out of pump.
    Next, remove water hose and look at filter washer.
    Clean or replace filter washer.
    Turn on water and it should come out of pump on other side.
    These steps will tell you if problem is water supply or pump.
    Sometimes the problems happen because the gun lever is bad.
    Hook up hose but not the gun
    See if pressure comes out hous.
    These steps will tell you if problem is gun or hose.
    Oct 25, 2010 | Honda Garden
    I bought this about 2 months ago i have used it twice in the middle of rinsing my truck off the high pressure got really faint now it is not spraying hard at all what could be going wrong
    We had problems like that before with our power washer. The pumps go bad. Even on new equipment. What's your warranty look like?
    Another thing is the water gets stopped up.
    Remove gun and hose.
    Turn on machine and see if you get full pressure shooting out of pump.
    Next, check the incoming water line.
    Most power washers have a screen washer >>> replace screen washer, then fire up again without hose attached.
    Gun triggers also fail. I think we had to replace guns when they went bad.
    As a rule, I always read the manual front and back.
    There are interesting things in the manual that neither of us know right now.
    The manual may give you a hint.
    If you need more help, answer back and I will look up the manual if available and see if together we can troubleshoot the problem further.
    Oct 24, 2010 | Honda Black Max 2600 PSI Pressure Washer
    Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
    Hydraulic oil?
    Is this a pressure washer?
    Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
    Engine should have 10W30 motor oil.
    If you have a pressure washer ... and not water is coming out end of gun:
    Take all hoses off machine.
    Look at incoming water hose connection.
    The should be a filter washer.
    Hook up water and turn on water.
    Turn on power washer and see if water coming out of pump is pressurized.
    Now hook up pressure hose without gun.
    Turn on pressure washer and see if water comes out of hose and is pressurized.
    Finally, the gun may be bad.
    We used to replace guns when they went bad.
    Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
    My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
    Good news, your engine runs
    But your pump may be bad
    Here's how to test your pump
    Check oil as outlined lower down
    Disconnect the washer hose and gun
    Connect water hose and turn on water and water should pass straight through the pump
    Look for clogs in the hose-end where water hose connects to machine
    Turn on machine and see if water shoots out pump
    If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
    Look for clogs in the end of each water connection.
    Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
    Finally, the gun trigger mechanism may be bad
    I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
    Check your pump oil
    Pump oil is SAE20 or SAE30 non-detergent motor oil
    Pump should be no more than 1/2 full of oil
    Use plastic hose to drain pump oil
    Do not turn machine on its side or turn machine over or engine oil will run into carburetor
    Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
    Garden Logo
    115 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
