Question about Music
Kimball upright piano serial number 134285 - Music
  • 5603 Answers
SOURCE: We have a Kimball Player upright,it has model C
Find the coil voltage and whether it is AC or DC coil andd the contact configuration. The search for relays at Digikey,com,, and others.
DO NOT replace the relays UNLESS you can see that the contacts are bad and fail to close. If the relay fails to move, verify the coil is open with an ohmmeter since a bad driver transistor will fail to actuate the relays.
OFTEN you can fix a sticky relay. You may find contamination in the magnet area that keeps it from closing. Remove a relay and actuate it observing operation looking for the problem.
SOME relays are used to protect speakers if the power amps don't balance... one can damage the speakers in this case. Manually actuating those relays will result in a pop in the speakers although sound MAY come out.
Posted on Jan 23, 2011
  • 560 Answers
SOURCE: Hi. looking to get some insight as to value of our john wanamaker piano serial number 127167
Call in an appraiser.
Posted on Dec 17, 2014
  • 31 Answers
SOURCE: how do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Posted on Feb 27, 2015
  • 3368 Answers
SOURCE: Age and value of my Kimball piano
I would suggest looking up the serial number and googling it on the internet.
Posted on Apr 03, 2015
Testimonial: "Thanks I forgot to enter serial#"
  • 37 Answers
SOURCE: what year was a hallet davis piano with serial number 187613 made
Posted on Jul 04, 2015
Need some information on a Kimball piano made in 1950 serial # 517474?
517XXX is a 1950 Kimball.
This site has some Kimball info and will do an appraisal for $20.
Sep 13, 2017 | Music
Kimball piano Console serial number 610660. It is in good condition and was purchased new by the owner.
what is your question if this is about value have a music shop do an appraisal
Apr 27, 2017 | The Music
I have and antique Kimball serial number is 197287 trying to find out the value of it
Kimball piano values vary based on age and condition; as of 2015, many uprights sell for $10,000 or more. Kimball is a well-known brand, and several of its antique pianos are considered highly collectible.
The Kimball Piano Company, based in Chicago, was one of the largest piano manufacturers in the world. At the turn of the century, Kimball built approximately 20,000 pianos annually. Kimball produced pianos under different brand names such as Hinze, Dunbar, Whitney and Harrison. Styles were influenced by Victorian, Greek Revival and Arts and Crafts architecture, and upright models were often available as player pianos. Kimball was sold to the Jasper American Corporation in 1959, and its pianos were discontinued in 1996.
Apr 08, 2017 | The Music
Chas f. Netzow upright piano Serial number 47686
I should write this out to save me keep typing it. Remove the front of the piano and the lid for the keyboard. Remove the middle C key completely. You may find the manufacture date and its full service history written in pencil on the side of the key.
Netzow Piano Co. Brand Name: Netzow Piano Co. Parent company: Netzow Piano Co. Location: Milwaukee, Wisconsin Serial Numbers Available: yes First date listed: 1904 Last date listed: 1931 Other brands:
Hi Robyn:
serial 10305
This was one of the original pianos made by this company in 1904. The serial number is the determining factor in telling a piano's age.
The worth rests on the piano's viability, configuration, and age.
Old uprights are generally worth little, especially if they are not serviceable. The furniture value is secondary.
If your piano is in perfect condition, inside and out, the value would top out around 200.00, USD.
What you have there is a typical upright piano, which more than likely has more furniture value than instrument value.
Age is not good in the piano world and pianos deteriorate year by year whether they are played or not.
Are you using this piece as furniture, or instrument?
9k= 3 yearsy ago #3 jim H. Guest I have a Netzow upright #41459. What is the manufacture date?
Made in 1913.
Netzow Piano Serial 13072 What is its manufacture dat
Feb 07, 2016 | Music
I have the warranty no for a kimball upright piano 848943 what can i find out
nothing from us as we do not serve Kimball check with them
Jun 02, 2015 | Music
Apr 02, 2015 | Music
I recently acquired a Kimball console piano serial# 498804. Wondering what year it was made and approximate value in good condition?
The information on indicates that serial numbers between 488000 - 499999 were produced in 1947.
Oct 14, 2014 | Music
Music Logo
21 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
