Question about Panasonic KXTGA653B Phone
Messages full but I have no messages - Panasonic KXTGA653B Phone
I have nokia N 73..I am recieving messages but unable to open as it says memory full delete some data..whereas my memory is not at full.I hardly have any data.I am unable to open my sms's .please help
Please go into inbox and delete all previous text messages. Then sent items and delete all text messages. Also in outbox, drafts. Your settings for your text messages may only be set to recieve a certain amount of texts.
You can change this by going into messages then message settings
and then other. increase the number of saved messages to 999.
If your phone is only set to save 100, you will get memory full messages once that amount has been reached.
Hope this helps and please rate
Mar 26, 2011 | Nokia N73 Cellular Phone
What does it mean when i send a text message it says message not saved memory is full or messages are locked?
This means that your sent memory is full, if you delete your old sent messages then you wont see that message anymore. Just go to your messages, look for sent messages, choose settings, delete all, confirm and you should be done.
Mar 07, 2011 | LG enV3 VX9200 Cell Phone
I HAVE A SHARP UX-A450 FAX MACHINE AND WANT TO EMPTY THE FAX MEMORY.
MEMORY IS FULL / SEE MANUAL (alternating messages)
The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages:
It is important to erase received messages after you listen to them to ensure
that the memory does not become full.
? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY.
? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY
IS FULL and SEE MANUAL will alternately appear in the display.
? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up.
? Press STOP if you want to cancel the entire transmission.
Nov 25, 2010 | Sharp Office Equipment & Supplies
My LG suddenly stopped saving outgoing text messages. I get a message saying memory is blocked or full.
Is it "blocked" or "full"? If it's full, then you have no choice but to delete some of the existing messages you have kept.
Both saved "Sent" messages as well as "Received" messages will fill up the message memory, so it helps to do some management in both areas, and clear out old messages so you'll have room for the new ones.
Jan 18, 2010 | LG enV3 VX9200 Cell Phone
Full memory
Erase Messages
Single Messages
You can erase a message itself, leaving the Caller ID information.
• While the message is playing, press and release DELETE. The unit erases the current message and announces, "Message erased."0
All Messages
You can also erase all the old messages only, leaving the new messages and Caller ID information.
While the unit is in ready-to-answer mode, press and hold DELETE until the unit announces, "Messages erased."
• New messages can not be erased in this way. To erase new messages, play them then press DELETE during play back.
Here is a link for the manual for your phone:
http://www.home-electronics.net/ge/pc/IB/29897GE1_IB.pdf
May 09, 2009 | GE 29897GE1 Corded Phone
Message memory full
Welll i too have a sony erricsson mobile.Actually Son phones has a limitation that only around 200 msgs can be stored in ur mobile.Although u may have free memory in ur phone i.e ur phone memory is not full but ur message memory is full.One thinh u can do is to store some messages on ur sim card.Sim card have some memory like my sim card can store upto 20 messages.Otherwise u dont have any choice but to delete the messages.
Thanks!
Sandy
Apr 30, 2009 | Sony Ericsson Cell Phones
Message Box is full. How do I erase?
Erase Messages
Single Messages
All Messages
Apr 26, 2009 | GE 29897GE1 Corded Phone
6280 memory full
Steps to follow when the phone memory is full:
  1. If the message memory is full you’ll be shown Memory full. Unable to receive messages is
  2. To delete old messages, Select OK and Press Yes and the folder.
  3. Navigate to the desired message and Select Delete.
  4. Choose Mark, to delete more messages. Mark all the messages you want to delete, Choose Options and Press Delete marked.
Feb 10, 2009 | Nokia 6280 Cellular Phone
Says machine is full, but there are no messages on the machine
make sure you retrieve all messages . I mean you may have 0 new messages, but you have lots of old messages ,it may full too.
Otherwise, delete all message, try to record incoming message or record your personal greating. Make sure the record function work, record chip works as well.
Jan 15, 2009 | GE 29875GE Digital Answering Machine
Messages full symbol will not go away!
try turning your phone on and off again, hopefully, it might work! it could also be that you have unsent messages in your outbox. goodluck if not, you should probably taked it back.
Nov 16, 2006 | Motorola Mobility RAZR V3
Panasonic KXTGA653B Phone Logo
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
