Question about Sewing Machines
National sewing mechine model#290
Thread keeps closing on underside
    Novelist:
  • 231 Answers
Check tension, also look for pieces of lint, dirt, dust in area where bobbin is.
Posted on Dec 07, 2016
The bobbin keeps balling up?
Can you provide more information on what type of sewing machine you have? Brand and Model would help. Thanks.
Jun 02, 2016 | Sewing Machines
My stitch does not sew on right side of fabric. I sew & see the underside of the stitch. I remove the fabric & the stitch is on the underside.... Never known sewing machine to do this. Help!!
Hi. first thing is to remove the threads from the machine, top thread and the bobbin, and replace to manufactures instructions. If still the same the problem sounds as if there is no tension on the bobbin [under] thread, adjust to a light tension. Then adjust top thread tension until the knot is in the middle of the cloth. Most times people keep tightening the top tension..
Aug 10, 2013 | Brother XL-2600I
My top thread keeps snapping on my consew 118. There are loops on the underside when I stitch with it and the thread keeps snapping at the needle. It is threaded right but it keeps happening literally...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Thread looping on the bottom of your fabric can be caused by little or no top tension or too much bobbin tension. Another cause is thread or lint caught in the top tension.
Make sure the thread is between the tension discs and that no thread or lint is caught
Apr 09, 2013 | Sewing Machines
Bobbin tension
Masses of thread on the underside is actually a top tension problem. If you can see into the top tension area, make certain there are no jammed threads, lint, yecch in there. Lift and lower the presser foot lever and see if the tension opens and closes. If it does not, it may be stuck open and not putting any tension on the top thread. Make sure your top tension is set in the middle of its range.
Apr 28, 2012 | Singer 57817 Computerized Sewing Machine
Sewing on top is fine but bottom bobbin keeps sewing messy on the underside domesco sewing machine how do i fix?
It is in your top threading, it is not threaded right. Make sure that there is no tangles in your thread, no bent needle. Check your threading by, presser foot up, pull thread, it should move smoothly, put presser foot down and pull thread again, now it should hardly move. This will seat the thread in the tension discs.
Feb 27, 2011 | Sewing Machines
My machine is stitching, it just keeps bunching on the underside of my material and I end up with this wad of thread. Why is it doing this?
check to see if the needle is damaged
some sewing machines bunch up on the underside when the thread come off the thread take up lever
Sep 27, 2010 | Singer 3116 Simple
My Pfaff 7550 sewing machine will ball-up thread on underside
Make sure your tension is set on 5 and you don't have dirt stuck in your tension unit.
Jan 18, 2010 | Sewing Machines
I need to see a diagram of a National Sewing Machine to see how to thread it. Can anyone help?
If you have one of the oldewr machines go to www.sewing-machine-manuals.com and click on relics, then scroll down to National and see if your model is there
Nov 07, 2009 | Sewing Machines
Sewing Machines Logo
46 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
