Question about Lexmark X5470 All-In-One InkJet Printer
When the paper tries to feed it will go half way and stop printin
How do I fix this problem?
    Master:
    Sergeant:
  • 226 Answers
Try wiping down the rollers with alchohol that should do it
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Posted on Jul 20, 2009
Canon k420 copier
In some cases, not all; the paper feed rollers get dry and slick. If so they tend to feed at times and sometimes stop halfway at times. Look at your rollers.
Jan 17, 2014 | Computers & Internet
Printer paper pulled half through then stops
Leading cause of paper jams or misfeeds is debris or foreign objects that fell accidentally in the paper feed area. Try to remove the sheets of paper from the feeder. Grab a flashlight and look into the feeder for any obstructions.
Also, try to open the printer cover and make sure the paper path is free from foreign objects or debris.
Re-insert your cartridges and make sure they are properly seated in the carrier.
Dec 23, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Canon imageCLASS D860, starts fine feeds paper through toner end then stops half way through. Sytem shows paper jam, but paper just stops moving. I can open it and lift paper out. paper wt. 20
try cleaning the pick-up and feed rollers with alcohol and see if that takes care of the problem. if it does for a short time that you need to replace those rollers
Feb 19, 2011 | Canon imageCLASS D860 All-In-One Laser...
Brother mfc-7420, how do I get off manuel paper feed
Thank you for following me up, I managed to discover that the document I was trying to print was set up for manuel paper feed, other documents subsequently went back to normal after printing the offending document. However is there a setting on the actual printer to control this.
Regards John
Oct 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Canon MP530 ADF
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
HP PSC1510 Feeds paper half out then stops
Clean the roller that feeds the paper (located at the right side inside the feeding tray).
I did it ,with a cotton pad: first impregnated with water an soap, then only with water to clean the soap and then with a dry pad. I did making the roll to roll printing a page without paper in the try and continuosly presing the cancel/resume button.
Mar 11, 2008 | HP PSC 1510 All-In-One InkJet Printer
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
