Question about Samsung Tablets & eReaders
Is there any way to unlock the Samsung tab Ativ smart pc 500T AT&T locked
Samsung ativ 500t smart tablet won't turn on after installing new battery
A lot of thing could have happened when you opened up your Tablet. Samsung makes it tough to change out batteries in Tablets.
Jun 05, 2016 | Samsung Tablets & eReaders
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube
    • 3 MIN
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
    May 23, 2016 | Samsung Tablets & eReaders
    Won't turn on- we bought a new battery and charger and no luck
    you need to plug it in for 5 seconds,,take out charger and replug repeating this for about 10 mins.keep repeating,it will charge eventually
    Feb 04, 2016 | Samsung Ativ Smart Pc 500t Tablet With...
    Arter upgrade window 8 to window8.1 now had problems internet connection limited , can't search anything now
    This was an official upgrade offered by Samsung, or did you use another source?
    Be aware a tablet is not a PC. The different microprocessors and internal architecture can make them all react different. Only use Samsung certified upgrades. When you did and it does not work as you like, just contact Samsung support on this link:
    They really help.
    Jan 18, 2015 | Samsung ATIV Tab 3 10.1" 64 GB White...
    This is a MS problem related to loading of nvidia drivers. MS do not have a solution but if you start in safe mode and remove all nvidia drivers and all references to them and a all folders containing them and then restart again in safe mode and download it all again, then restart in normal mode so windows can find the new drivers this has worked for a number of people. Hope this helps you.
    Feb 19, 2014 | Samsung ATIV Tab 5 11.6" LED HD Tablet...
    Tablet won't turn on
    Your net power might not be sufficient; e.g. when it is like a bathroom power connection it is not sufficient
    Dec 30, 2013 | Samsung Ativ Smart Pc Xe500t1c 11.6" 64 Gb...
    Cannot unlock my tablet
    Do you men the network unlock?I suggest you can approach and specify the country,locked network of your Samsung Galaxy Tab.Based on the availability you can get the unlock code along with free instructions.
    Dec 03, 2013 | Samsung Galaxy Tab Tablet PC
    Samsung Ativ Tab doesn't want to switch on
    I have the same problem... Did you find the problem and/or solution?
    Sep 21, 2013 | Samsung P8510 Ativ Tablet 64GB Gray
    Tablets & eReaders Logo
    32 people viewed this question
    Top Samsung Tablets & eReaders Experts
    Jaime Hernandez
    Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
