Question about Dyson Vacuums
Dc59 won't charge - Dyson Vacuums
I have lost the top to the filter on my Dyson, DC59 GT9-US-FJC3318A. Will you help me get another?
Variant Parts - Dyson
https://www.dyson.com/parts/variant-parts.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Dyson parts for DC59 Animal. Carbon fiber brush bar $22.99 Replacement Carbon fiber brush bar assembly for your Dyson DC59 vacuum cleaner.
Dyson Vacuum and Fan Replacement Parts - Official Site ' Dyson.com
www.dyson.com/parts/select-variant.aspx?category=Cordless
  1. Cached
Find spares and replacement parts for your Dyson vacuum or fan. Select your machine model to see a full ... Dyson Hard DC56. Dyson DC59 Cordless Vacuum ...
Spare parts for DC59 Animal - Dyson
https://www.dyson.co.uk/spares/variant-spares.aspx?pid=DC59-animal
  1. Cached
  2. Similar
Image of Soleplate rollers Soleplate roller pack £1.50 · Image of Wand assembly Wand £55.00 · Image of Crevice tool Crevice tool £10.00 · Dyson Combination ...
Dyson DC59 / DC62 Animal Vacuum Cleaner Parts
www.partswarehouse.com/Dyson-DC59-DC62-Animal-Cordless...s/6871.htm
  1. Cached
  2. Similar
Dyson DC59 / DC62 Animal Cordless Vacuum Parts, Accessories, & Repair Schematics. Free Shipping Available - PartsWarehouse.
Genuine Parts and Accessories for the DC59 Dyson Cordless Vacuum ...
https://www.dysonspares.ie/index.php?route=product/category&path=66_285
  1. Cached
Genuine Parts and Accessories for the Dyson DC59 range of Cordless Vacuum Cleaner. owerful handheld vacuum which boasts a brushless switched reluctance motor. It is small, light and powerful. Dyson DC59 Google Search
Dec 26, 2016 | Top Vacuums
Inherited from family member who moved away, can't see how the charging cord fits into docking station as it doesn't line up with hole on vacuum body when inserted into docking station.
Hi there, it's Jack at Dyson.
All DC59 models were supplied with the docking station design shown below, which sounds as if it's the one you've seen in videos online:
From your description, it sounds like the docking station you've inherited may belong to an older Dyson cordless vacuum, such as DC35 or DC44. If you're able to call the Dyson Customer Helpline directly, we should be able to help determine exactly which docking station you have, and whether or not it's compatible with your DC59.
You can reach our experts by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
May 07, 2016 | Dyson DC59 Animal Cordless Vacuum Cleaner
When I plug it in to charge the blue charging light comes on for 2 or 3 minutes then goes out and charging stops. Have I blown the charger by constantly leaving it plugged in? Please help!
Hi Alvina, it's Jack at Dyson.
DC59 will display a blue indicator light at the base of the hand grip while the machine is taking in power. The light will go out when the machine is fully charged. DC59 will take 3.5 hours to charge fully when the charge is completely depleted, but it will take less time than this if there is still some charge remaining on the battery after use.
Please note, the machine's intelligent control software is designed to ensure the battery only takes in enough power to recharge, and to keep itself topped up. It's safe to leave the machine connected to the charger at all times when not in use - the machine is designed to be stored in this way, so it's always ready to go when you need it.
From the information you've provided, I'm not clear on whether or not you're finding your DC59 works as normal once the blue charging light goes out, or whether it's not working at all. To make sure everything is correct, please get in touch with our experts directly. We'll be happy to talk you through some simple diagnostic checks when you have your machine easily to hand.
You can reach the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
Feb 27, 2016 | Dyson DC59 Animal Bagless Cordless Stick...
Why isn't it charging?
I'm sorry to hear your DC59 doesn't seem to be charging. If you're recharging your machine in the docking station, make sure the end of the charger cord is correctly and firmly inserted into position. If the charger cord is not correctly installed, it may not be making effective contact with the machine. In normal use, DC59 should recharge from depleted within 3.5 hours.
If you're plugging the charger cord directly into the machine and have continued to experience this issue, please get in touch with the Dyson Customer Helpline directly when you have your machine to hand. Our experts will be happy to talk you through some simple diagnostic checks - and if a replacement part is needed, they can confirm if this is covered under your Dyson warranty.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 21, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
I have had my dyson dc59 for about 3 months. Wheni try to turn it on by the trigger it won't start. I know it has a full charge so with my messing around with it i pressed the max button and it turned...
Hi Jeff, it's Jack at Dyson.
The issue you're describing with your DC59 sounds very unusual, but I'm sure we can help. Like all Dyson cordless and handheld vacuums, DC59 is backed with our 2-year Dyson parts and labour guarantee.
When you have your machine fully charged and easily to hand, please give us a call so we can talk you through some simple diagnostic checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 23, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
How do I fix my dyson DC59 as it won't charge
Hi Karen, it's Jack at Dyson.
In order to help you further we would need to take some additional details about the issue you're experiencing, as well as exactly how you're recharging your DC59 between uses.
When you have your machine easily to hand, please give us a call so we can talk you through some simple diagnostic checks to confirm which part may be at fault. If a replacement part is needed this should be covered under your 2-year Dyson guarantee, as long as the machine has been used and maintained according to the User guide.
To reach our experts directly, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jan 29, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
My dylon DC59 isn't running smoothly ie it pulses, this didn't happen a week ago when I bought it?
Hi Sue, it's Jack at Dyson.
DC59 will pulse to let you know if something is blocking airflow from moving through the machine. You can resolve this easily by checking the floor tool, wand and bin inlet for any obstructions - the pre-filter may also need a wash. Just follow the steps shown in our video guide:
I'm confident this will resolve the issue, but if you'd like some further help from our experts after giving this a try, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Nov 30, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
How do i know the dc59 needs charging
The Dyson DC59 cordless vacuum has two LED indicator lights on either side of the handgrip, which you'll see where the battery attaches to the handgrip. These will flash to let you know when there's less than 1 minute of charge remaining.
Once the charge has depleted, the machine will shut off - the power won't trail away gradually as with some cordless products.
If your DC59 is making an intermittent pulsing noise when you hold down the on/off trigger, this is likely to be because a blockage in the motorised floor tool, wand or bin inlet is preventing airflow passing through the vacuum. If this is the case, please follow the steps shown in the video below to clear any obstructions:
I hope this answers your question, but if you'd like further assistance from our experts you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 14, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
When I try to use my Dyson DC59 it won't start and blue lights on both sides of the battery start blinking. What does this mean?
From what you've described, it sounds as if you may be using your DC59 set to Boost mode. This will provide 6 minutes of highest suction for really stubborn dirt, but for regular vacuuming normal mode should work effectively.
To switch back to normal mode, ensure your machine is fully charged (this will take a maximum of 3.5 hours), then hold down the on/off trigger, and at the same time, press the illuminated Boost button on the rear of the machine.
You might also find our Getting started guide useful:
I'm confident this will resolve the issue, but if you would like some further advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 13, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
Lost the charger for my dyson dc59
Visit your local vacuum cleaner store that is a Dyson warranty and repair facility. If they don't have it they can order it for you.
Mar 23, 2014 | Vacuums
Vacuums Logo
29 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
