The code HD keeps popping up - Televison & Video
We have a error code L 6 that keeps popping up. What is it?
L6 is usually a motor issue but need to know which L6--
Mar 20, 2014 | Sharp AL-1000 Copier
I keep getting error code 8002f147 on my ps3 when it tries to update
take out the hard driveconnect hard drive to pc (running windows 7 64bit, but any windows os should work without other software)open up disk management - in win7 it asked me to make a master boot record, so I did.format in NTSF - that's right, NTSF - don't use quick formatshut down pc, take out hd, take usb drive tooput hd back in ps3, put usb stick in ps3boot ps3a screen will pop-up saying the hard disk have to be formattedhold start + Select for 5 sec.After formatting the system will restart and the update will start installing configure your ps3 setup - done
Feb 23, 2014 | Sony Playstation 3 (PS3) Console
Menu Keeps Popping Up
There is either a short in the menu button on the TV or it is sticking/dirty.
Jan 30, 2014 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Sony wall mounted 740hd pops from hd to non-hd
it has to do with the brodcast testing digital frequenies. they will probably solve them selves when the change happens.
Jun 03, 2009 | Sony Bravia KDL-32N4000 32 in. HDTV LCD TV
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Message: missing or not connected HD
Try to remove and reinstall the HD and memory module(s) and see if that doesn't help. If not, get back to me for some more ideas. Thanks!
Dec 14, 2008 | HP Compaq Presario C304NR Notebook
First of all, is your blue "HD" light lit up on the front of your Uverse box?
If yes, then you're in HD
If No, you need to check your connections from Box to TV
1.Those Red-Blue-Green cables are for video only, they don't carry sound and shouldn't be connected to audio outs. Audio needs a seperate cable. Make sure your Red isn't on the audio out which is also red. Make sure your blue and green aren't switched with each other either. Check that at both ends.
2. Try an HDMI cable. It will carry audio and video together and it's one cord instead of 5.
3. What brand/model of TV is it? Is it an older projection TV? The HD tuner might be shot. The individual color tubes commonly fail after a few years.
4. Are you selecting 720p or 1080i from your TV's menu or from the Uverse menu? You'll need to set it through the Uverse box, not the TV.
5.Follow -Menu -Settings -Aspect Ratio to change to 720 or 1080. This should start an autotest which will scramble your picture for about 5 seconds, then bring you back to a menu asking you to keep settings or revert back settings. If you never see that question pop up, then your TV isn't supporting the HD, and you settings will be rolled back automatically. If the question does pop up and you can read it, select "keep settings" and press OK. Your blue HD light should come on the front of the box now.
Mar 01, 2008 | Philips 55PW9363 55" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
