Question about Refrigerators
Refrigerator is freezing everything and we have the control temp set at 3 which is below factory settings.
    Master:
  • 552 Answers
A refrigerant leak can cause this
Posted on Dec 09, 2016
HVACRH20
  • 237 Answers
SOURCE: Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Posted on Dec 26, 2006
Bob Gemmell
  • 209 Answers
SOURCE: Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
Posted on Sep 28, 2007
  • 71 Answers
SOURCE: refrigerator is too cold. Freezing milk and vegs.
sounds like the solenoid door is broke or stuck ,unless you are real handy , just tape up the air inlet in the refrigerator little by little until you get it right.
Posted on Dec 15, 2008
bobicehouse
  • 1524 Answers
SOURCE: My refrigerator freezes my food solid
Replace cold control
Posted on May 03, 2009
woodchuck789
  • 4066 Answers
SOURCE: My Frigidaire refrigerator side by side is freezing drinks.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Sep 22, 2009
Refrigerator keeps freezing even after settings have been rased
37 for the refrigerator and 0 for the freezer is the factory starting point. If you are still having problems with freezing in the refrigerator, bring the temp of the freezer up above 0
Mar 27, 2015 | Kenmore Refrigerators
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Sep 22, 2009 | Frigidaire FRS26H5AS Side by Side...
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Refrigerator side temp keeps dropping below freezing.
Set the freezer temp control to MAX cold and see if it improves.
If not replace the off/on thermostat.(cold control)
May 24, 2009 | Kenmore Refrigerators
My fridge freezes everything
If the temperature outside the refrigerator drops below the temperature inside such as in a non heated garage the things in the refrigerator will freeze. Short of moving the refrigerator to a temp controlled place there is not much you can do about it.
Jan 07, 2009 | Freezers
Refrigerator freezing over
if you haveno control of the temp. it is the cold control t-stat that is bad, but first i would sett all controls to factory setting and allow to run for 24 hrs to confirm
Jun 01, 2008 | Kenmore Refrigerators
Refrigerator Problem
Could be the temp control is not registering temps correctly. If you leave is below 6 does everything warm up? The compressor should only run when it needs to, not all the time. In other words, if you put it on 4 will the food stay cool (about 38F)? A typical unit only runs a few minutes a day if the doors are not opened up all the time.
Feb 02, 2007 | Avanti 310SST Compact Refrigerator
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
