Question about Baby Lock Sewing Machines
We were just given a babylock serger and the fabric won't advance. The dogs don't seem to be moving.
  • rickmcconn Aug 05, 2009
    Rayzer85, Thanks, I had already found the 2 set screws. htey appeared slightly loose but when tightened it seems the machine runs for just seconds and then doesn't have the power to spin just hums unless you hand turn it. Could it be the motor doesn't have enough power? I have tried to find different postions for the dogs, cleaned everything, but still no luck.
    Rick
  • 46 Answers
Depends on the model but some machines have a problem that the feed regulator cam has become loose (2 set screws) and will not advance the material. A good Babylock dealer will be able to diagnose quick.
Posted on Jul 25, 2009
  • Paul Howell
    Paul Howell Sep 01, 2011
    Most likely the feed regulator cam needs to be replaced. After removing and replacing it, the feed timing must be reset.
How to move feed dogs under needle for singer 514
First, make sure the feed dogs are in the up position and NOT dropped for darning.
Second, check that the stitch length is set to at least a 2 or 2.5 to make sure the feed dogs will actually move the fabric a noticeable distance. The closer the stitch length is set to zero, the closer together the stitches will be until it will sew only in one place because the fabric will no longer advance.
The feed dogs need to move. They should actually rise, move toward the back of the machine, drop down, move forward to the position to again rise--this creates one stitch. If the fabric is not moving, then it is possible that your machine has not been cleaned and oiled recently. Old oil will dry and cause the moving parts to seize.
It was working now it seems to be frozen the needle part wont move
Mar 07, 2016 | Singer Sewing Machines
Brother 1034d handwheel stuck
the best thing to do is take the machine in to have it checked.
sergers are nice & very useful, I have a babylock serger with the jet-air
looper threading systerm, and I use it alot when making clothes.
I even used my serger to serge the ends of fabric that I haven't used yet
so the ends won't fray.
Jun 11, 2012 | Brother 1034D Mechanical Sewing Machine
I have a JukiLU562 and fabric won't move starting to sew
the feed dogs are what move the fabric thru the machine to sew it
if the feed dogs are not working, then they need to be checked
to see if they have some loose or broken or need to be retimed
Jun 05, 2012 | Juki Sewing Machines
I am on the second letter of an embroidery pattern and the needles keep breaking. I have tightened everything as much as possible. I have never had this problem before. I am using the correct needles. Any...
I have a babylock serger & I use SCHMETZ UNIVERSAL NEEDLES on the serger & I don't have any problem with the serger
you should also check the tension to make sure it correct for fabric & needles
also make sure the needle is not in backward--flat side goes to the back of the machine.
if you need a manual contact babylock customer service
Mar 26, 2012 | Singer Quantum XL-1000 Computerized Sewing...
What is wrong with new home overlock serger when motor is slugish or won't move.
there is something wrong with the machine, the feed dogs are what move the fabric, it could be many different thing, the motor, some part is worn or loose or broken, power cord, it needs to be serviced
Feb 27, 2012 | Sewing Machines
Feed dog on Serger Babylock 5260D
Make sure that the presser foot dial (the silver "knob") on top of the machine is not too loose. You can adjust this w/ a nickel; tighten it all the way down & then loosen about 4 full rotations for cotton fabrics. Also make sure the Differentail feed lever is on "N". You can order a book from your local Baby Lock dealership for all models. Good Luck.
Mar 19, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Feed dogs on serger don't advance
I use my BLSE200 all the time and ran into the same problem just last week. After pulling out my hair in frustration, I finally realized it had to do with the stitch length. Something wasn't connecting after I adjusted the stitch length, so when I re-set the stitch length, it popped things back into alignment and the feed dogs started working again. *whew* Hope that helps!
Jan 18, 2009 | Baby Lock Eclipse Serger
Sewing Machines Logo
286 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
