Question about Toshiba Televison & Video
How do I access the channel search without a remote control on a Toshiba model 27D47. The only buttons are Power, Volume and Channel.
  • Clifford Thompson
    Clifford Thompson Dec 06, 2016
    Toshiba phone support doesn't assist with televisions anymore and the website doesn't help with this model number anymore.
    Top Expert:
  • Toshiba Master
  • 74,999 Answers
Without a remote control, you can't as there is no Menu button at the front panel of this TV. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
If you wish to get further advice over phone; visit
Posted on Dec 14, 2016
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
crazy larry
  • 6 Answers
SOURCE: how to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Posted on Feb 23, 2008
  • 520 Answers
SOURCE: am i able to get into the menu of small orion tv without a remote
It may be possible to access the menu by holding down both volume buttons for 10 seconds. If not you probobly need the remote.
Posted on Dec 19, 2008
SOURCE: finding AV channel without a remote control
get ewf 2004 on av channel without remote
Posted on Feb 19, 2009
SOURCE: Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Posted on Sep 14, 2009
Can i run a channel scan on a toshiba model number 32HL66 without a remote
You should be able to access all features with the menu button on the TV itself. You make selections on the menu with either the Volume or the Channel buttons. On screen instructions should guide you.
Nov 29, 2015 | Toshiba Televison & Video
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; also has a replacement remote available that has been programmed for the TV. (On, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
How do I get free movies? I only get paid ones
Configurations on Roku TV without Remote
·How to obtain settings on Roku TV without remote? You can navigate and control the TV settings with the particular Roku mobile application procured from the app store and users can also access additional features on the app. Now the user needs to connect the Roku streaming device with the mobile device to the same wireless system across the devices. If the customer do not have a new valid Roku account and then user needs to create an active account by making use of the How to can Roku TV be accessed without any Remote Controller:
Accessing channels
    ·Download and install the particular Roku application on your own mobile device.
    ·To launch the application navigate to the My Channels options.
    ·Your Roku account channels lists are screened now. Using your mobile or notebook computer as a remote and perform the following functions:
      ·Changing channels using the channel upward and down arrows.
      ·Changing the volume control making use of the volume up or down arrows.
      ·Play or pause a video.
      ·Reverse scan and forward scan.
      ·Channel search.
      ·Adjust your television volume utilizing the volume control keys on your mobile gadget.
      ·The user initially requires Roku account activated with procedures to enable connecting the Roku device with the Mobile app.
      How to get to settings on Roku TV set without remote and search for preferred media content:
        ·Use the particular drop down menu availed on your Roku mobile app.
        ·Select Roku Search option and search for channels or even other content available upon the channel store.
        ·As a universal search, this search will fetch additional channels information also.
        ·From the search results the user can choose the channel of their choice.
        ·To enjoy these functionalities the user is in need to perform the to create a valid Roku account.
        The user can add and remove channels using the Roku's home screen and click streaming channels option. Log into the Roku account with the appropriate password credentials and select the channel and move to the 'Add a Channel' option and based on the account settings, you might be asked to provide the PIN and pay a subscription if required else the channel will get added to your Roku accounts instantly.
        For any further queries that how can the users get set and access on Roku TV without a remote controller or procedure user can contact our online agents to guide you on this in simple and instant means. This can be done through by using the toll-free number at +1-866-990-6730 or visit our site at
Aug 21, 2014 | Televison & Video
How can i tune channels on my thorn ct512t without the remote control
There is a button on the television, You check at the lower end of the television or on the side of the television. There You have the menu button, then You will see the channel and volume button, those are to navigate through the main menu after pressing the menu button.
When You press the menu button, You will see the main menu page, then You navigate with either the volume buttons or the channel button to channel settings, then You go to search, then You select either the auto search or the manual search, then You search and save Your channel using the buttons as earlier used.
Hope this helped.
Thank You for using fixYa
Jun 10, 2011 | Televison & Video
Hi, what is the sky remote code for Toshiba TV model 32BV500B? Thanks.
I've found two codes that work fine on a revision 8 Sky remote control and a revision 8r remote:
0056 (LG/Goldstar)
981 (General reset)
Both codes enable volume, channel selection and power on/off.
Nov 11, 2010 | Toshiba Televison & Video
I have a Sony Trinitron model KV27S35, but no remote. How do I program the tv without the remote?
The SETUP button on the case accesses the menu.
Press Channel +   to select Language.
Press Volume -    - now the tv will be reset to factory condition.
Press Channel + to start the AUTO PROGRAM and wait for it to finish.
Press Channel -  to exit it.
That is all. If you need more then all the menu options can be accessed thru the key on the tv.
Aug 17, 2010 | Zenith ZN110 Remote Control
How do you tune in a alba tv with no remote control
There is no way to tune it, the menus that you need to bring up can only be accessed with the menu buttons on the remote
Feb 28, 2010 | Televison & Video
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
No Remote - Need to access Menu
on some sets you can push both the channel up and down buttons to access the menu, then use them and the volume buttons to navigate the menu. otherwise you may have to get a programmable remote control.
May 30, 2008 | Televison & Video
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Televison & Video Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
