Question about Electrolux Dryers
My Electrolux dryer T5310 show O.H Thermostat inlet air and does not start.. what should I do.can u please suggest me on it?
Electrolux dryer EWMED65HSS isn't starting- There isn't any noise when I turn the knobs- display panel does initial light up but nothing shows on it. Any suggestions? Already checked power cord
Check your power supply/plug in outlet for proper voltage, e.g. 240 volts or 120 volts on portable dryers first. if that checks out, the next thing to check is the door switch, followed by the thermal limiter. Always disconnect power from its source before attempting diagnosis or disassembly.
This link can help if you need to go beyond that.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Nov 25, 2017 | Electrolux Dryers
Electrolux Insight Iron Aid. Why does it steam up kitchen?
Electrolux Wave Touch Dryer Problems. It Leaks! - YouTube
? 2:12
https://www.youtube.com/watch?v=uMFpFVOFE5M
Sep 27, 2012 - Uploaded by erik malewski
My less than a week old Electrolux Wave Touch Dryer leakedfrom the perfect steam inlet all over my ...
Water under my Steam Dryer (May: condo, appliances, house ...
www.city-data.com > City-Data Forum > US Forums > Oklahoma
Aug 15, 2012 - My washer and dryer is an Electrolux designed in Italy to Sears ... wasleaking; but the repairman said it wasn't and that the dryer just had built ...
Electrolux steam dryer Questions & Answers - Fixya
Jan 01, 2016 | Dryers
Electrolux dryer error code e62
Good Afternoon Friend,
I understand you are receiving an E62 error code on your Electrolux dryer, model# EIED55H. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Electrolux EIED55H Dryer
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
Countdown timer not working
I understand that the timer on your Electrolux dryer, model#EIMED55IIW, is not advancing to show you how much time is left on the dry cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Restore power and restart your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 18, 2014 | Electrolux EIMED55IIW 8-0 cu- ft- Electric...
Electrolux Gas Dryer: E66 error
Should the heater wire have electrical continuity to the housing
Mar 08, 2012 | Electrolux EIED55H Dryer
ELECTROLUX DRYER T4130, error code E08 show on panel. have tried turning power on and off, but still the error code E08.
Dryer had been overheated (clogged or damaged air filter). Reset 3 thermo-fuses (small red buttons): 2 under top cover and 1 under back side round cover
Jan 02, 2011 | Electrolux Dryers
My new Electrolux IQ 8.0 cuft dryer smells like burning oil or grease when you run it. I just got it yesterday and have run 4 loads. It still stinks. My husband thinks this is normal. Is it?
From http://tedmalone.blogspot.com/2009/06/dryer-problem-solved.html
It turns out that the inlet vent in most dryers is louvered to mix in some outside air with the air being heated by the gas (~ 500 degrees F). In an effort to be more efficient, Electrolux removed these louvers and have not been able to lower the heat enough in their gas dryers to keep from burning clothes. Furthermore, it turns out there is a *new part* which if you're in-the-know you can order. It is the same part, but with the louvers back.
Jan 23, 2010 | Electrolux Dryers
Electrolux Lavamat Turbo 16830 Washer/Dryer but dryer not working
Has the little belt on the dryer turbo come off? or is the turbo seized - it should turn freely by hand. You may need to replace the turbo fan if the belt keeps coming off - the pulleys can get out of alignment, ie not running parallel to each other - they tend to be cheapo plastic construction these days. Could also be dryer elements or thermostat problems, or blockage with lint causing reduced air flow and overheating - but check belt first.
Nov 28, 2017 | Electrolux EW1209i Front Load Washer /...
Dryers Logo
93 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
