Question about Measuring Tools & Sensors
Megger mit insulation tester - Measuring Tools & Sensors
    Master:
  • 683 Answers
Posted on Dec 23, 2016
HOW TO RESET megger MIT510/2 MANUAL NSE?
nSE means "No Specific Error".
The recomendation is return your devise to workshop
Jun 12, 2014 | Megger MIT510/2 5 kV Insulation Resistance...
Why power can not switched on after battery replaced
if your unit worked before battery change - check battery connections and also if there is any fuse there - make sure that everything is connected as before and that battery that you replaced is a new one
Note: When battery is replaced service performs battery retraining (you cannot do that)
if that does not help - send it for service
Nov 10, 2013 | Megger MIT1020-2 10kV Insulation Tester
Power can not be switched on after battery disconnected
it's battery operated unit (I think)
connect battery back
Megger MTI 1020/2 I got E79 in screen what dose it mean thank you
I checked the user manual and could not find an answer to your question. Try calling this service center:
Megger
4271 Bronze Way, Dallas,
Texas 75237-1019 USA
T +1 800 723 2861 (USA ONLY)
T +1 214 333 3201
F +1 214 331 7399
E ussales@megger.com
Mar 15, 2011 | RTO Megger 10 Kv Insulation Resistance...
AO Smith SQ1102 pump motor: how do I wire this thing? How do I know if I set it to 115 or 230? I justed popped my 20 amp fuse.
On your motor name plate there is a diagram with motor terminal numbers that shows you the feeder wires connections for 115 & 230VAC. You don't need to change any internal motor wiring connections because those are only CW or CCW motor rotation. As you told it tripped your circuit breaker, b4 u will attemp to make any connection you need to test your motor's winding insulation insulation first by using megger tester or ordinary analog tester clipping one lead to the casing and one lead to the motor terminals one by one.
Mar 06, 2011 | A.O. Smith SQ1102 Pool Pump Motor
Im involved in an Insulation Resistance Test for Motors & equipment. The specs call for a tempeture reading: ambient, and ''Readings Corrected 25degC'' What does this mean?
Taking the ambient temperature means that you to take the temperature of the air that surrounds the motor. If the ambient temperture is 25 degrees C (or 77 degrees F) you do not need to make a correction to the motor insulation resistance reading that you get from the megger.
If the ambient temperature is, say, 97 degrees F then you would want to adjust your megger reading according to the correction factor table provided by the megger manufacturer at 97 degrees F.
Just multiply the megger reading by the ambient temperature correction factor.
Apr 06, 2010 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
