Question about Dryers
Vibration of Dryer
My Dryer squeaked, so the repair people replaced the rear bearing and the drum glides (it's a fridgidaire). It doesn't squeak anymore, however, now, it is vibrating near the end of the cycle. What may have happened?
  • karensalas Jul 20, 2009
    Thanks for responding so quickly. However, you said washer, did you mean dryer. It's my dryer I'm having problems with. Could it be that the repair guy tightened something too tight when he installed the bearings or the guides?
  • 158 Answers
It may be off one of the guides. Or a balance problem. It may be a bit off balance. Now that you have a new bearing your machine is going to work better. It will spin faster because of the new bearing. When it spins faster you will get vibration. If it is not shaking badly, Try to load your washer balanced. If there are any more questions please feel free to ask. I will help you untill we have this thing solved. Please leave good feedback for me, it means a lot to me, and I will really help you all that I can...
Posted on Jul 20, 2009
Dryer is squealing during the first few minutes its on then the noise stops. Is it the glides?
Depending on the dryer you either have a central rear ball bearing and glide pads in the front or you have 2-4 rollers supporting the drum. Any of these can squeak. Also the belt tensioner can occasionally squeak.
Aug 11, 2013 | Dryers
Model 8600 , drum makes loud noise, not a squeak
HI,
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Jul 26, 2008 | Maytag Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer squeaks when drying clothes.How do I fix this problem
Here is a tip that I wrote to help people figure out why the dryer is making squeaking. bangin, or clunking nioses...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
May 04, 2010 | GE DRSR483EGWW Dryer
GE Dryer DDE7900 squeaking.
it could be the drum belt that has glazed from age or the front drum glides/rollers or even a rear bearing on the drum
Nov 14, 2009 | Televison & Video
Dryer has thumping noise.
Yes that is what most likely is the problem to begin with. The drum usually never goes out of round . Replace bearing best choice
Aug 28, 2009 | Dryers
Dryer has a squeaking noise. does it need to be
Change the belt and check all of the bearings for play. If any have too much slack replace them.
Jun 23, 2009 | Dryers
Dryer makes a squeaking noise
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
thanks and please do not forget to accept the solution
Apr 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
118 people viewed this question
Top Dryers Experts
