How to inputthete symbol in programme - Washing Machines
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
When I try to start a programme the ERR symbols flashes. I have deactivated the the machine problem recurs
The display shows Err. :
  • If you want to set a new programme, deactivate
    and activate the appliance.
  • Make sure that the options are applicable to the
    programme.
Dado
Mar 02, 2015 | Zanussi Dryers
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
Symbol DS9808 will not scan barcode
Hello Dbird,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for DS9808.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Dec 02, 2010 | Zebra Symbol DS9808 Barcode Scanner...
Symbol 4000i scanner will not scan barcodes that are single digit
Hello Jane Diaz,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for LS4000.
Oct 13, 2010 | Symbol LS 4000i Handheld
How can i use \\ this symbol in toshiba portage a600
\\ this symbols is above the enter key, just press twice.
more often used for programmers at the begining of some routines or programs
May 12, 2010 | Toshiba PortegeA600-S2201 Notebook
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
