Black arm between the ribbon spools does not move from side to side causing the ribbon not to advance
JUSTOLDJIM
  • 478 Answers
SOURCE: IBM Selectric used ribbon won't wind into spool
The ribbon sometime gets wrapped around the ribbon driver,One lever on the right side only releases the lift off tape for removal the other is for ribbon removal, also check that the ribbon is on the outside of the ribbon tensioner where the ribbon exits the cartridge on the left side ( a wire thing with a plastic tube on it.
Posted on Jan 29, 2008
Geno111
  • 183 Answers
SOURCE: Olivetti Lettera 22
duplicate submission
Posted on Jan 06, 2009
Geno111
  • 183 Answers
SOURCE: Olivetti Lettera 22 - Ribbon Spool doesn't advance.
these are tricky to repair, I would suggest taking it to a repair shop (check the yellow pages) check repair directory on this site, sorry , no easy answer on this one
  • 19 Answers
SOURCE: Ribbon spool does not turn, TEC B452
If you are working with the driver, change in stock page direct thermal to thermal transfer.
Posted on Mar 26, 2009
  • 3594 Answers
SOURCE: I have a circa 1940's-50's Royal Desktop
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Posted on Oct 18, 2010
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
Olivetti Underwood Studio 44 ribbon won't advance.
Remove the top cover, remove ribbon spools, press a key and grab it with your finger, note the mechanical motions toward the ribbon advancer movement, usually found near the center of the ribbon holder or could be on the outside edge also, there is a reverser mechanism also that should be fully to one side or the other, it switches the ribbon direction to avoid a 'dead end' while typing. By moving the key toward the platen and away it should drive the ribbon mount spool by a shifting drive lever of some kind. If you cannot resolve this issue, take it to a rare typewriter repair shop, it is too hard to explain in this format, and mechanical skills are involved, hope you have them, ;)
Sep 14, 2013 | Underwood Retro green Olivetti Studio 44...
I have a new black and red ribbon for my Smith Corona Silent Super typewriter. I took the old one out a long time ago. I know the red half goes on the bottom and the black on top but I am not sure which...
Most ribbons wind to the outside of the spools. Take the ribbon off, type and watch the take up spindels to see whitch way it moves and install the ribbon that way.
DickyO
Jul 15, 2011 | Smith Corona Office Equipment & Supplies
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
How to install typewriter ribbon on a Sears typewriter model no 2
I believe this T/W takes a Gen. Ribbon T5 or T7. Check to see which way the spool turns over 90% wrap to the outdide of the spool. Put it on to wrap in that direction, the ribbon will have an eyelet about 6" from the end be sure that is wrapped on the spool. From either side put the ribbon tru the reversing arm, tru the lifter, tru the other reversing arm and back to the other spool.
DickyO
Jan 19, 2010 | Office Equipment & Supplies
The ribbon wont advance
The ribbon drive on this model are gear driven..a .may be off, a loose set screw on one of the gears..the ribbon may be the wrong one or it has a ribbon reverse lever on the side of the machine, this should be free of binds.
Hope this helps........
Squipps
Oct 07, 2009 | Royal Office Equipment & Supplies
Old typewriter Brother DELUXE 800 : ribbon reference ?
This is what you are looking for:
Brother Typewriter Ribbon spool black and red SC-20BR-BRO Compatible
The typewriter ribbons for use in Brother manual typewriters are usually all the same. What matters is the size (diameter and hight) of the spools.They differed only in that they were available in different colours (usually black or black and red) and in different materials: some ribbons were made of nylon (cheaper) and other made of silk (more expensive and higher quality) .
Maybe some old and good stationer's (papeterie) still carries them or has some in stock.
Or else you may want to contact the customer support service of Brother, in France, for advice on where to find them in your Country.
Sep 07, 2009 | Brother Office Equipment & Supplies
How to install correction tape in the GX-6500 Typewriter?
Move carrier to middle with spacebar.
Open lid, remove black ribbon and old correction tape.
Gently pull new tape apart a few inches. attach take-up spool (empty one) to right post.
Pass through right ribbon guide, sticky side faces platen!
Unspool carefully thread through left ribbon guide.
Attach feeder spool to the left post.
Turn the right spool to tighten.
GL
Jul 04, 2009 | Brother Office Equipment & Supplies
Ribbon replace on ibm selectra 2
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Feb 08, 2009 | IBM Wheelwriter 30 Typewriter
Jan 29, 2008 | Lexmark Wheelwriter 15 Series II...
108 people viewed this question
k24674
jasbo
jasbo
