Question about Sewing Machines
Parkray fire cumbria , can i burn wood in the fire if i remove the throat plate
  • Sewing Machines Master
  • 11,732 Answers
You're burning a fire in your sewing machine?
Posted on Dec 06, 2016
Phaff throat plate 98-694826-00
hi beth.
not sure what you are asking,but try this link out.
Pfaff throat plate 98 694826 00 Google Search
Nov 03, 2017 | Sewing Machines
My needle is hitting the plate when I try to make a buttonhole
Sue: According to http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCAQFjAA&url=http%3A%2F%2Fwww.consew.com%2FFiles%2F112347%2FInstructionManuals%2FCN2230R.pdf&ei=ZGtVVaa7OYKRyQTGo4GoBA&usg=AFQjCNG-1xhxBFtfhJZJn7y5QZ_0E1r48w&bvm=bv.93564037,d.aWw : "The Throat Plate is not held firmly in place. Its screws are not tightened securely. The Throat Plate shifts around and is being hit by the Needle. Solution: Locate the Throat Plate correctly and tighten firmly the throat plate screws."
May 14, 2015 | Sewing Machines
I took the throat plate off to clean my Imagine serger. When I try to put bak on it has to be pushed back down and is against a small piece, seems to be too close.
THROAT PLATES ARE HELD ON EACH SIDE WITH A SMALL PIECE OF METAL (SPRING). 1. PLACE THE PLATE AT AN ANGLE OF THE THROAT. 2. AT THE SAME TIME CAREFULLY PUSH EACH SPRING UNDER THE PLATE. 3. SLIDE THE PLATE TOWARDS THE AREA WHERE THE PLATE SHOULD FALL INTO THE LOWER POSITION.
Feb 26, 2015 | Baby Lock Imagine
How do you replace throat plate on Babylock Imagine Wave serger
I had to replace the Needle Plate on my Babylock Ellegante machine and when I turned on the machine it told me to Turn off power and replace the Needle Plate. which I had already done. How do I fix that so I can sew. thanks Jan billawp@tds.net
Jul 14, 2012 | Sewing Machines
How do you remove the throat plate?
Not sure what you mean by 'throat plate' - do you mean the stitch plate/needle plate ? If-so, the best way is to drop the feed-dogs by pressing the button in the bottom of the handwheel end panel and you then press firmly on the back right-hand corner of the stitch plate - it should then pop-up on the opposite corner and you can remove it. It's held-in by two spring retainers. When replacing it, position it so that the hole in the front right corner of the plate is over the locating lug first and the right-hand side of the plate is in place, then press the left-hand side down into the grey plastic surround in the free-arm.
Hope that helps.
Jan 27, 2012 | Bernina Artista 180
Please help my throat plate[needle plate] is banging loudly..the faster I sew the louder it knocks[throat plate against its base]..it's as if its too loose but see nowhere to tighten or screw it in...
I would like to help you but I do not know what model your machine is. Please answer this and I will try to help you. Knocking is usually lint built up under the throat plate and has to be removed to get it cleaned out.
Apr 18, 2011 | Singer Sewing Machines
Removing needle plate from viking sewing machine
throat plate is usually tight with screws may be that the holding magnet and once the button is located near shuttle and it should press plate up...
Dec 24, 2009 | Husqvarna Viking 1
The fabric does not feed properly.
Remove the throat plate and clean out the lint in between the feed dogs (teeth). Make sure the throat plate is not bent downwards where the needle goes through. Also, after removing the lint turn the machine over by hand, the feed dogs at their highest point should be about 2mm above the throat plate.
Also, try this link, there are many free books.
http://www.singermachines.co.uk/Parts_&_Ser/indstbooks.htm
Jul 06, 2009 | Singer 3116 Simple
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
