Is there a protocol to check the proper function of my modem??
Computer recently slower. Do not know what my current modem is set at.
  • Computers & ... Master
  • 10,263 Answers
Run some antivirus software first to see if your computer is being used by others. You cannot change the speed of your modem by internal adjustments. Clear out all cache locations. Download a program called ccleaner. It's free and works well.
Posted on Dec 06, 2016
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Hi guru, i wish you help me please!! i condigured my wireless router actiontec and i have internet acces in my pc by cable ethernet, but when i try on my laptop by wi-fi or with my celphone, it says that...
Ethernet gives network signals from computer server with connectivity capacities. Once the ethernet is connected to your computer, once of the computers within the network structure has a modem or signal converter box to capture and distibute signals. Your computer is functioning with ethernet cable connection as arranged default. Recent computers however have wiifii capacities meaning that, the modem box is not ncecssary to make signals recognised. Recent computers have builtin signal recepticles, once the programs wireless features are enbled, any available computer networks aer detected. Howver, the wiifii makes connectivity to networks by requesting password keys if the aletrnate computers have protected the entry. Simply said, your computer is ok to function with ethernet as regular achievement. only when the ethernet is malfunct usually caused by the computer that has the modem disconnecting from yours. Your computer should actually get better networking with only one of the method available either ethernet or wiifii. Attempting to receive signals with wiifii and ethernet at the same time impedes the network speed since the structures may only allow an amount of data passage for each network on the same computer. Use the computer wireless buttons located at the system settings area to disable the wiifii until a computer request within your knownlege request to activate wiiffii. Keep in mind that once your wiifii is enabled, another computer is sharing resoruces makign the computer slower if a password was not set.
Feb 04, 2011 | Computers & Internet
Not providing valid IP addresses
make sure that your router is acting like a DHCP server.
also make sure that your pc's ip is set to "obtain automatically" under local area connection->properties->internet protocol->properties
Jan 25, 2010 | D-Link DSL-G624M (0790069285783) Wireless...
Everytime i set up my router it says "your ethernet cable does not appear to be connected properly. Error 321: Ethernet Cable not connected" now i have tried setting this up multiple times but i keep...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 04, 2010 | Linksys WRT120N Router
Difficulty making an internet connection
thirddaylw, go into the modem settings and make the speed a constant or a lower speed that what is currently set and see if it allows you to connect thereafter.
May 22, 2009 | Psion Gold Card Global 56k plus ISDN...
Cannot Detect Modem during installation
You should start by having everything off then power up the modem and wait for all the lights to come on then power on the router after all the lights come on then turn on your pc. If you are not getting these results I would reset the modem and the router and then follow the instructions above. Resetting the modem and router will revert then to the default settings, that might be helpful to start with fresh settings.
Question: Is this for your laptop?
May 23, 2008 | D-Link DSL-G604T Wireless Router
Protocol v90
Hey
Got some stuff for u
Try this:
How to disable the V.90 protocol
1. Open "My Computer".
2. Open "Dial-Up Networking".
3. Right Click on the icon used to connect with, then Left Click on "Properties".
4. At the bottom of the window, Click the button "Configure".
5. At the top of the next page, Click on the Tab called "Connection".
6. Near the bottom of the next page, Click on the "Advanced" button.
7. At the bottom of this page, Click in the "Extra Setting" box and type in the appropriate code.
(see below for appropriate code)
Motorola - Hayes modems
Disable Flex to 33,600 or less
+MS=11,1,300,33600
Motorola SM56 pci speaker-phone modem: *mm13
OR GOTO
http://www.psknet.com/support/FAQ/initstrings.htm
Check whether this works or not
Feb 19, 2008 | Computers & Internet
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
PPP control protocols
Who ever the ISP is that you are dialling cannot agree on the PPP protocols. In other words your ID to that network is wrong. It does not matter what OS you running. Go back to the ISP you must have one before you can connect. Depending on where you are and who that ISP is you will not and cannot connect until these protocols ie; ID and password have been established. If you have all of those and you thinks there is a problem go to them it sounds like your modem is fine.
Sep 07, 2007 | Computers & Internet
Configuring EDIMAX 6104 for Aztech 600E Router
Does your router automatically set the ip addresses for each computer, or do you have to set them up yourself? Is the computer that can connect the one that is directly connected to the modem? if it does and you asked windows to repair the connection it probably is messed up. check in the router settings to see if your pc's are on the same ip address route (e.g 192.168.x.x), but not all the same last digit; and the subnet masks are all the same (eg 255.255.255.0)
Oct 25, 2006 | Edimax BR-6104 Broadband Router. One...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
