Question about Canon imageRUNNER 2200
Canon toner for 2200 used to have how to diagram on box to change cartridge. Need step by step directions please
  • 149 Answers
Ok, open the front door and rack back the blue handle to free the developer unit. The unit that moved to the right as you turned the lever - pull it towards you as far as it will go - be careful though because the retainers in place to stop the unit falling out may have been removed and not put back. The whole unit would fall and you'd have a great mess. Now, once you've pulled out the unit far enough to reveal the top cover with verticle ridges on it running from the front to the back - unpack your toner cartridge. Before removing any seals or plastic, turn the cartridge with it's flat edge facing down and using the end of it with the longer ridge, slide it onto the unit that you've pulled out until you hear a click. The cartridge should now be sitting exactly on top of the unit with no overhang. At this point you grab the two blue handles on the unit and the handles on the cartridge and pull them slowly towards you. This will release the toner down into the developer unit. When the plate you have being pulling towards you is out to it's full extent, the cartridge gently to make sure all the toner drops into the dev unit and then push it all the way back in until it clicks and unlatches itself. The cartridge would now be closed and sealed to stop too much stray toner falling. Do this whole procedure slowly. If all was in place properly, you've just changed your toner - good luck.
Posted on Jul 20, 2009
How to clean the magenta toner sensor on a canon imagerunner c5255 copier
Step 1Turn off and unplug your Canon copier. Put on a pair of latex or work gloves to keep toner and debris off of your hands. Cover a table, desk or other surface with three to four sheets of newspaper to protect the surface from spilled toner Step 2Open your copier's toner cartridge door on the front or top of the device and remove the toner cartridge. The cartridge contains the drum as part of its unit. Lay a flannel cloth onto the newspaper-covered table, desk or other surface and then shake the toner cartridge gently above the cloth to coat the cloth lightly with ton
Place the cartridge upside down on the newspaper-covered surface and open the drum's shutter door, which contains hinges. Rotate the drum using the spindle on the side and wipe the drum's surface with the toner-covered flannel cloth to remove any dust, dirt and caked-on debris. The drum only rotates in one direction. Work quickly so as not to expose the drum to light. Artificial and natural light can damage the drum's surfac Step 4Continue rotating and wiping the drum's surface until it is free of any debris and dirt. Close the drum's shutter door and reinstall the cartridge back in your Canon copier.
Sep 28, 2016 | Canon Office Equipment & Supplies
Change toner
Step 1 Check the top of your Canon fax/copy machine to see if your specific model has a protruding extension piece from the plastic delivery tray. Push the extension piece down if one is present on your model.
Step 2
Grip the bottom edge of the paper delivery tray at the front of the machine. Lift the tray upward to reveal the rectangular, plastic toner cartridge inside the machine.
Related Reading: How to Add Toner to a Canon X25
Step 3
Grab the handle at the top of the current toner cartridge and lift the cartridge upward. Pull the toner out of the machine and set it aside.
Step 4
Set your replacement toner cartridge over the empty space in the fax/copy machine. Ensure that the arrow near the bottom of the cartridge is facing down, and line up the protruding guide piece on the left side of the cartridge with the groove inside the machine. Push the toner downward until it snaps into position.
Step 5
Push the paper delivery tray back down, and lift up the extension piece if your model uses one.
May 06, 2015 | Office Equipment & Supplies
I cant get the toner cartridges in my canon c ir 2050 to go back into the copier
Try these steps.
  • Pull out of the front cover of the Canon 2200 so that it flips down and exposes the inside of the machine.
  • Remove any toner cartridge already in the machine by pressing down on the blue lever located near the bottom right of the inside of the machine. Then grasp the toner box right above the handle and slide it out until it stops.
  • Hold the new toner cartridge in both hands and shake it from side to side a few times to loosen up the toner.
  • Orient the toner cartridge so that the flat surface is facing downward and the small handle at the end of the surface is pointing toward you.
  • Place the toner cartridge on top of the toner box. Push it back in as far as it will go and then press down on the cartridge until you feel it click into place.
  • Pull back on the small handle on the top of the cartridge. A thin separator sheet between the cartridge and the toner box will come out. Continue to pull until you see a stop sign on the separator sheet.
  • Tap on the toner cartridge to cause the toner to vacate the cartridge and fall into the toner box. After you have tapped it a few times, push the cartridge handle back in. When the handle goes all the way back in, you will feel the cartridge unlock from the toner box.
  • Remove the empty toner cartridge and push the toner box back into the machine. Pull up on the blue lever once the box is all the way in. Close the front cover to the Canon 2200.
Hope this helps.
Jun 29, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
Don"t know to change the toner it was donated and
There are usually picture instructions on the Canon toner box. But here it goes - Gently shake the toner cartridge to break up the fine toner powder. Then open up the front door, the you should see a blue handle on the right side, rotate this in the counter clockwise direction. The Developer should move to the right and gently pull this out as far as it will go. Put the toner cartridge on top of the developer assembly and gently push down until it locks in. You will have to angle the rear facing end of the cartridge so that it slips into a slot. When the cartridge is lock the tab should break away. Before pulling this tab away from the copier lift up on the cartridge to guarantee that the cartridge is locked into place. You don't want to pull the tab until locked because you will have abig mess to clean up. The tab will open up the developer unit and the toner will drop inside. The you close up the slide and at the end of this procedure you may have to place a thumb on each side of the slide and fingers on the blue finger catches to fully close the developer unit. The cartridge should release and then remove the empty toner cartridge. Throw it away, return the developer to its normal position, close the front cover.
Jun 20, 2011 | Canon imageRUNNER 2200
Change the toner cartridge
There is instruction how to change toner on lcd display of copier, wich pops out when the toner is out.
Jul 21, 2010 | Canon imageRUNNER 2200
Change toner cartridge , how do i
Open front cover, realese the blue toner handle, pull out toner unit, put toner crg. on top toner unit, so that arrow poits to copier. Press it and then will pop out tape wich you pull out, not to the end, when it does not go further it is OK, push back the plastic cover that got out, this will realese toner crg.Remove empty toner crg, push back toner unit and lift handle.
NOTE: when toner is empty machine guides you how to change toner on lcd display, you just need to look and press next.
Jun 30, 2010 | Canon imageRUNNER 2200
Remove toner
you push in on the front top where the stop strip was and it will pop up unless you have yet to add toner to the developing hoppper then you would fallow the directions on the toner box
Mar 17, 2010 | Canon ImageRunner 3320N Copier
Trying to find documentation for the Canon Imagerunner 400S. Need to know how to add toner?
Did you look on the box the toner comes in? Also, when the copier needs toner, the display panel will walk you through the steps of how to install a new toner. The hardest part is getting the toner cartridge OFF. You need to press the front of the developing unit right under the blue cover on the front. The Black piece will push in to release the toner cartridge. Good Luck...
Jul 07, 2009 | Canon imageRUNNER 400S Copier
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon imageRUNNER 2200 Logo
139 people viewed this question
old marine
old marine
