Question about Humidifiers
The base is over filling with water drowning out the vapor. This is a new uhe-cm65
Instruction manual for Homedics humidifier model UHE-WM62GY?
Try Googling (homedics)(UHE-WM62GY)(manual) without parens.
Jan 11, 2018 | Humidifiers
How to clean homed is humidifier
Hello, Mary -
This is the link to the PDF document with the Instruction Manual for the Homedics Humidifier model UHE-CM45:
https://www.homedics.com/media/documents/homedics/instructionbooks/UHE-CM45_IB.pdf
Cleaning instructions start on Page 9 of the instructions.
You can download and save the instructions as well as print them, if you wish.
Best wishes.
Jan 08, 2018 | Humidifiers
Homedics Humidifier UHE-CM45
Check the float that is monitoring the water level. Sometimes lime and calcium build up will restrict the motion of the float. If it's a probe level, check to make sure there is no hard water build up on the probes that will restrict continuity from one probe to the other
Aug 15, 2016 | Humidifiers
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
Ultrasonic humidifier's fan isn't running, the light indicated red instead of blue, and there is no mist coming out. How to fix it please since we cannot afford for another one right now.
I had the same problem. Looked up the manual online. Red light indicates water level is low I had just refilled the tank so that was not the problem but manual said to make sure water tank was firmly, securely seated on base. I unplugged the unit, unscrewed the plug on the tank and screwed it back on and then made sure the tank was securely seated on the base, plugged it in and it started working. If the tank is full you may just have to make sure the tank is fitting properly in the base.
Feb 05, 2014 | Homedics Uhe-oc1 Cool Mist Ultrasonic...
Hi have a vicks warm steam vaporizer model v188. works great, just wanting to clean it. Can't find my manual anywhere.
The easiest ans simplest way to clean it, is too mix a 50/50 solution of White Vinegar & Bottled Distilled Water (enough to fill the tank) and fill the the tank with the solution. Allow it to set for 30 minutes, then turn the unit ON. Allow it to run, until the tank is half empty. Pour out the remaining solution and fill with the Bottled Distilled Water Turn the unit ON and run until the tank is almost empty. Following these instruction will remove all the lime and calcium build up in the unit.
Tip: Using bottled Distilled Water rather than Tap Water, will totally eliminate calcium and lime buildup.
I hope this helped you and thanks for choosing FixYa.
Aug 13, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
How do you fill the venta humidifier I don't have
http://www.appliancefactoryparts.com/content/pdfs/123738.pdf
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
Dec 24, 2010 | Venta Airwasher VS 207 3.7 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Air o swiss 7133 doesn't send out any vapor
Interestingly enough as soon as I posted here, I was able to find the source of the problem. It appears that during cleaning the water level sensor, a bobber which normally floats as the water level rises, became stuck the to bottom of the water base - see below for the picture. I was able to use a small wooden spoon to lightly apply pressure and release the bobber so that it could float, and instantly the vapor started flowing again.
Aug 24, 2008 | Air-O-Swiss 7133 Humidifier
Humidifiers Logo
53 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
