Question about Gamo Optics
I am trying to find some recommended pellets for a gamo tac whisper air rifle. What do you recommend....177
erpaalai
  • 999 Answers
SOURCE: need help putting back together my air rifle.
http://www.crosman.com/pdf/manuals/CS1K77_CS1K77X%20EVP%20&%20PARTS%20LIST.pdf
If this is not your model the list is here
http://www.crosman.com/airguns/service/manuals/crosman-rifles
Eric
Posted on Jan 16, 2010
Adrian762
  • 425 Answers
SOURCE: i took apart my crosman .177 pellet rifle, and
See the answer:
http://www.fixya.com/support/t4047835-put_trigger_back_together
Posted on Feb 08, 2010
agent91
  • 2100 Answers
SOURCE: I Have a crossman .177 air rifle, that you have to
Some air gun problems are an easy fix, some require extensive presses and jigs to move springs around. Most are not to messed with. I know, I have tried my best to repair an air rifle or two and had to send them back to the company to get them fixed. And there is nothing I can't fix, I have a big machine shop, been gun smithing for years and couldn't fix a little air rifle. Check out this website, it might help you, or steer you in the right direction. ,,,,,,,http://www.airguns.net/faq.php#faq1
Posted on Mar 09, 2010
agent91
  • 2100 Answers
SOURCE: How do I adjust my scope on my Crossman bb/pellet rifle .177
Assuming the scope is ok, and the gun is ok, it must be the shooter, Not you but the stance, holding, bench rest, something is not consistent. If I was you, I would set up a big piece of cardboard at 15 yards, get the rifle on a beanbag or a bench rest, aim at a one inch spot in the center of the cardboard, shoot about 3 times, depending on where the pellet is hitting, move the adj knobs accordingly, do it again, 3 times, adj, as many times as it takes, get it centered, then, shoot it about 3 times at a clean plate, if it hits it's mark 3 times, then you can try it standing, and you should be able to build confidence in it so you know where it shoots, and won't be discouraged. Now if the rifle is bad, or the scope mounts loose, you will fight the thing all day and end up trashing it. I would blame the mounts first, then the scope, then the rust spot in the barrel, rare. If it is a break action rifle, you can set it up in a box with v's cut into it, look through the bore at the target, make sure it doesn't move, the scope should be looking at the same exact thing, if it isn't, something is wrong. You can set it up this way to start, and then fine tune it with pellets. Check it out, hope this helps.
Posted on Aug 04, 2010
  • 3 Answers
SOURCE: the air rifle i have
once the oil burns off and leaves the barrel, try diff pellets as they do make a world of difference. i have a gamo shadow and use promatch. there are some better and more expensive ones but i have no issues hitting a 50c coin from 50m away. breathing, posture, your steadiness and your familarity to the trigger breakpoint all affect your accuracy.
Posted on May 13, 2011
Whats is the maximum grain size pellet that can be used for a whisper fusion mach 1 .177 cal
Any commercially available pellet will work. Some styles/weights/manufacturers shoot better in a particular gun than others. Impact points vary with aerodynamics/weight.
I experimented with different pellets to get the most accurate one.
Gamo makes a really good pellet.
Here's a pack with different styles -
GAMO Performance Pellets Combo Pack 177 Cal Multiple Styles 632092854 eBay
Dec 07, 2017 | The Optics
Where can i get a manual for a Gamo Cadet?
Contact them direct. The search link mentions manuals but none are listed.
GAMO USA ' Customer Service
www.gamousa.com/customerservice.aspx
AirRifles. Whisper Fusion ... The pellets should be placed in your GAMOairrifle with the skirt towards the stock ... Where can I get a manual for my GAMOrifle? A:.
Dec 02, 2015 | Optics
Can i but a new barrel how much
Bone Collector .177 and .22 cal special edition air rifles ...
www.gamousa.com > Air Rifle
The "BONE COLLECTOR" .177 and .22 caliber air rifles. ... blast reducer integrated into a bull barrel, and utilize the advanced IGT (Inert Gas Technology).
images for Bone Collector .177 Caliber barrel
Nov 07, 2015 | Gamo Bone Collector .177 Caliber Hunting...
Where can i find a owners manual. i bought it cheap from a friend but have no manual to it
http://www.airrifleshop.co.uk/Airgun%20manuals.htm
Has some gamo manuals not the specific one you want but has all the important info for safety and operation plus zeroing if its a parts diagram you want look at the following link
http://www.aceros-de-hispania.com/MANUALES-DESPIECES/DESPIECES-CARABINAS-GAMO/despiece-silent-stalker.jpg
Mar 29, 2015 | Gamo USA Gamo Silent Stalker Whisper...
Where is the serial number on a whisperer fusion
I have a similar Gamo air gun and the serial number is on the barrel on a flat spot on the side near the hinge.
Jun 29, 2014 | Caliber Gamo USA Hunter Elite .177 Air...
I have a bigcat and it will not shoot a gooup
I have one of the BIG CAT rifles and can shoot under 1" groups. First Check the gun and be sure it is tight in the stock. I had to remove the front screws and pot nylon washers under them to get the stock tight!
Second. I could shoot decent groups and the they would move! I replaced the scope mount with a better quality better fitting scope mount. Be sure it has the stop pin that fits in the hole in the top of the rifle or they will move to the back and never be stable.
Third. I replaced the Gamo scope with a Leupold 3X9 varix 2. I am not sure about the Gamo scope but while I was mounting a scope I decided to try the Leupold.
I have shot some 5 shot groups from a good rest that was less than 1/2". The factory scope mounts looked like a bad fit on the groves of the rifle and looked canted.
The best pellets I found are the PREMIER HOLLOW POINT and some of the worse were the GAMO FLATPOINT!
Dec 28, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
The air rifle i have is a Gamo Hunter Sport .177 It's accuracy is absolutely terrible. I realized that i had put lubrication oil in the barrel and was wondering if that might be the reason, and wanted to...
The first thing to do is clean the barrel, yes, oil in the barrel will cause accuracy to suffer. Next is get as good a pellet as you can and the flat tipped waisted, kind are the best for accuracy. See picture below --->>>> 216ef8c.jpg Next is to lube the pump or mechanism to get as consistent a pump as you can.
Oct 16, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
My gamo whisper classic with the nitro piston is recoiling hard and is deforming the opening on the scope stop. I just ordered the plastic bumper stop that Gamo makes but is this normal?
no its not normal,,,check that the piston crown is not braking up as if it was the piston would smack into the breach block causing the hard thump on firing
Aug 10, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
The magnification adjustment ring on my Gamo Whisper worked fine at first, then was stuck between 3X and 5X. Now it is free again but the scope is not focused on the 3X and 9X settings, but is clear on 5X...
I'm not familiar with the scope, is it an air rifle scope? One stroke type? If not, the backwards recoil of the air rifle is tough on a normal scope, they aren't made for that type of abuse. They work fine with a normal recoil. That is why they started making air rifle scopes. I'm sure that the internals of your scope are damaged somewhat, you can take off the eyepiece no problem, you might find something in there, loose screw, missing screw, you never know, don't get too carried away with the dis-assembly, you'll never get it back together. It sounds like the magnification ring is messing with the focus of the eyepiece. Might just need some oil. Hope this helps.
Feb 28, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
Optics Logo
49 people viewed this question
Top Gamo Optics Experts
Vernon Taylor
Are you a Gamo Optic Expert? Answer questions, earn points and help others
