Question about Miller Welding Tools
My miller 304 is overhesting,and smoke comes out the machine,what can I do, can be the capacitors?
  • Miller Master
  • 9,845 Answers
More likely the transformer has a shorted winding.
Posted on Dec 06, 2016
Testimonial: "Where I can buy parts for my miller machine,example the control board, one circuit is burn"
The minute hand is loose on our Howard Miller 625-304 wall clock. How do we access the hands, and how do we tighten them?
Open the bezel/glass and there will be a dial nut on the end of the hands, just tighten it up.
Main Page
Nov 07, 2016 | Home
There was a power surge and my Brother Innovis 600 sparked loudly with smoke coming out of the vents. It won't turn on. What do I do?
Hopefully this has a built in power supply. This would be the first place to look at. When the smoke comes out it is not a good thing !
I would check the electrolytic capacitors in the power supply circuitry. You may be lucky and could get away with only needing a replacement power supply , however other components may have been damaged there is no way of knowing if the power supply blowing up protected the other circuits in your device. if smoke had not come out I would check for fuses but with smoke a voltage regulator , capacitors in the power supply or even power diodes could be smoked and broken.
Find out by smelling what smells of smoke to narrow down the damage location.
Aug 12, 2016 | Brother Sewing Machines
I plug in my miller 304 cc cv welder, 220 voltage, the numbers flash randomly, wont balance out, wont weld, any solution
What does the voltage window display? If it is reading open circuit voltage then check your leads. You could have a front control board failed if not. You should probably take it to a miller tech to have pre power checks performed.
Feb 15, 2015 | Miller Welding Tools
I have a miller 304 pipe pro and I can not get the voltage or amprage lights to come on the digital display
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 11, 2014 | Televison & Video
I have a HEL p-6 code on a xmt 304 how do I fix it
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Dec 08, 2014 | Welding Tools
Viking Sewing Machine Model 205 began to smoke. I believe it needs a new capacitor. What will a capacitor cost?
you'll have to call a sewing machine repair shop tell them the machine
began to smoke & ask them what a new capacitor will cost.
Oct 02, 2012 | Husqvarna Sewing Machines
304 inverter: fan does not come on. unit overheats and stops
Hi:
On this unit the fan is on demand, but if it does never come on, you should send it to your nearest repair shop, your machine has 3 years warranty. Before you send it to the repair shop, try to reduce the operating voltage.
Good luck.
Jul 10, 2011 | Miller Welding Tools
Welding Tools Logo
383 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
