Question about Casio Music
I need a replacement LCD for my CTK631 keyboard.The part no. is LD-B10432E. casio say no longer available. I will bne happy with new or s/hand or even salvaged from a faulty keyboard. can you help?
  • 575 Answers
Check Ebay for a used keyboard or parts.
Posted on Dec 22, 2016
How do add songs to the song bank on my Casio LK-30 keyboard?
You can't add songs to the LK-30 song bank. I suspect you would need to take apart the keyboard and replace the ROM (read-only memory) chip to get a different song collection.
Most Casio electronic instrument manuals are available from . However, I found the LK-30 manual at .
I wish that I had better news for you.
Sep 30, 2017 | Casio Music
Most Casio keyboard manuals are available from their support page: . Here you will need to accept the Casio terms of use. Then scroll down to the correct model. The direct link to the User's Guide is currently . Casio also has an appendix and documentation on the MIDI standard on the Manuals page for the CTK-5000.
I hope this helps.
Mar 09, 2016 | Casio Ctk-5000 Electronic Keyboard Piano...
How do I factory reset my Casio CTK-2400 Keyboard?
You manual is here
Interestingly...check out page EN-34...about the section on local control...Follow the directions to turn your sound back up... Good luck
Feb 23, 2015 | Casio Music
How to replace a defective speaker on the Casio CT-638 tone bank keyboard
Hi, Yes it can be fixed.
It may not need fixing, It may have just worked loose. If it is faulty then any general purpose speaker that will fit will be OK. Consider replacing both if the replacement is radically different.
Speakers can be as cheap as a few pounds.
Paying someone to do the repair is something else. It will take longer to take the keyboard apart than affect the repair.
Consider buying a replacement from eBay, second hand, and get a competent amateur to repair yours!!
Failing that, use the headphone out (which cuts the internal speakers) into a hi fi or external instrument amp.
Good luck, Chris the Fader.
May 21, 2014 | Casio Ctk-5000 Electronic Keyboard Piano...
Keyboard AC Adapter
If thje voltage is the same, the current rating is fine at 1000-1400 mA. The accessory will use the amount of current it needs and the fact that there is more "available" does not mean it will use it. The higher current rating will not ruin the equipment. Just make sure the voltage rating is the same. Cheers!
Mar 09, 2014 | Casio AD5 Keyboard AC Adapter
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
The sound IC number is lost. What is the number?
The integrated circuit that are used are specially programmed for Casio and are not available from electronics stores. They are usually surface mounted and require special tools and skills to replace. You would need to take this to a Casio service center to replace the chip if that is the problem. Frankly, it is UNLIKELY that is the problem unless you can see burn marks on the chip. Keybaord contacts are the usual failure and require cleaning.
Mar 31, 2011 | Casio Ctk574 61 Key FullSize Portable...
What kind of USB cable do I need for my CTK-491 Keyboard, and where can I find it?
You will need MIDI cable - widely available from good musical instrument (keyboard) stores and on the internet
For more information about using MIDI on your keyboard see the appropriate section in teh user's manual here
Feb 10, 2011 | Casio Ctk491 Midi Keyboard
Need casiotone mt 36 manual please.
I went there as well I would try the MA 150 many times the instructions are very close to each model. If this still wont help, try Ebay and Yahoo there a lot of manual collectors there . You may even get lucky on YouTube good luck DFD please rate me
Apr 10, 2009 | Casio Music
Casio LK 200 and smf software
If you have the smart card slot you can save your songs to the memory card by using Anvil Studio which is a free program. Save your midi song in Format 0 and be sure to use channel 4 for right hand playing and channel 3 for left hand. Be sure to keep the file size under 80k if you have other channels active for other instruments!
Nov 06, 2007 | Casio Lighted Keyboard LK90STADMC
Music Logo
21 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
