I get digital on my tv all the time and it yakes forever to change chanels.
3 Suggested Answers
  • 13 Answers
SOURCE: Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Posted on Mar 18, 2009
gopakumarg43
  • 74482 Answers
SOURCE: tv won't change from chanel to chanel
Do a hard reset to this set and check first. To make it hard reset, unplug the set from AC mains wall socket, and re-plug it back after 10 minutes or so.If this do not help you, check and replace its main system memory IC.
Posted on Sep 30, 2012
When i switch off tv and turnit back i loose some of the chanels
You may or may not have a real problem with the set, using a antenna of some sort for this or what?
Dec 21, 2012 | Televison & Video
Tv won't change from chanel to chanel
Sep 29, 2012 | Sony FD Trinitron WEGA KV-20FV300 20" TV
My Goodman tv..When I change chanels I get sound but no picture. If I Turn it off and change chanel then turn tv back on I then get picture,Please can you help me withmy problem.Pat
Ocassionally. digital TV did not load correctly, and must reboot and load firmwware to get the digital signals for the TV. Changing channel is not necessary for firmware to load correctly. But powerline glitches might cause a problem..
Nov 17, 2010 | Televison & Video
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
Is my polaroid TLX-04244B Digital
I checked out the manual for a similar model tv from polaroid...there's only one input for the coax cable from your antenna, so if the antenna's cable is connected to this input, this couldn't be the problem. What I do have trouble with on my own tv is that my indoor antenna location can make huge differences in recognizing all available digital signals. I could even have the antenna facing a different direction, and get different results. There are a few sites you can google for to find your distance from the broadcast towers, too. This might help to determine if you need a stronger antenna. It's a painfully long procedure to try different angles and positions for your antenna each time you run a channel scan, but this might be the only thing that would prevent you from picking up the digitals. I try the highest spot possible, and the one closest to the outdoors. Good luck, I hope you can pick them up soon! (Any antenna works...the industry tries to pass off "digital/hdtv specific antennas" to make a buck. I've used a cheapy rabbit-ears antenna and was able to bring in digital channels, as long as your tv or converter box is converting the signal.)
Jun 13, 2009 | Polaroid TTM-2401 TV
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
How do I receive anolog stations on my VIZIO tv
you need to go into the menue, under setup and chanels, do the auto program, it will memorise all the chanels that you can get, analog, and digital, after that, just type in an analog chanel, if it goes to a digital chanel, hit the chanel down button
Jan 11, 2009 | Vizio L32 32 in. LCD HDTV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
