Question about Miele Vacuums
Miele vacuum model #S5280 when starting to vacuum Red alert comes on!
5 Suggested Answers
  • 6 Answers
SOURCE: I have a Miele Red
At GoVacuum we put together a General Miele Maintenance video together for Miele Owners. Although the video showcased in the video is not specifically your Red Star machine, the filter installation is going to be the same.
Check it out here:
Posted on Sep 03, 2008
  • 125 Answers
SOURCE: miele vacuum - red light
replace all your filters
Posted on Dec 06, 2008
  • 95 Answers
SOURCE: won't start
It is most likely your cord winder. They are a little tricky to fix yourself. A repair shop will probably charge about $50. To fix it. The contacts where the cord winder plugs into the motor need to be cleaned and adjusted. Just don't let your repairman tell you that you need a new cord winder.
Posted on Jan 24, 2009
  • 4 Answers
SOURCE: How to reset the Miele Type HS 05 Model S514?
Hi bud
sounds like ps3 has shut down as the gpu/cpu has popped of the board due to over heating and the use of lead free solder.there are places you can send it for repairs or you could have a crack at if with heat gun and liquid flux if your brave. Google it for a tutorial
hope this help you out
Posted on Jun 10, 2014
I was vacuuming my tumble dryer fluff build up out thoroughly and my miele s5280 cut out. It was obviously overheated but how do i re set it? i cannot see where ther is a reset on the machine or in th...
do not think there is one . try turning the juice off at the breaker then back on .if that doesn't work call a service man not good idea to have a dryer running when vacuuming tho
Mar 04, 2015 | Miele Vacuums
How do i put the vacuum bag on my miele pisces vacuum?
Hello, this is Ava with Think Crucial.
You may check the instructions on how you can install your Miele bag inside your vacuum using the link provided below.
Miele 5281 Pisces Operating manual
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Jan 26, 2014 | Miele Pisces S5280 Royal Blue Canister...
My Miele upright vacuum will not start. The red light will come on but not the motor. Why is that?
I believe you should have an amber light, if you are seeing a red light located above the bag compartment door, that indicates a fault with either the electronic module or the motor. Unless you have a voltage meter and are familiar with pulling plastic tabbed appliances apart, I suggest you email or call direct. Residential Appliances or Vacuum Cleaners(800) 843-7231Monday-Friday:8:30 am - 5:00 pm ESTSaturday-Sunday:Closed
Mar 04, 2013 | Miele S7210 Bagged Upright Vacuum
I have a Miele Silver Moon 558 and the red light is staying on saying reset - what do I do? - I do not have a manual. Thank you
well for the manual, you may download it from here. note that you will first have to give some kind of rating before download link activates. otherwise, light indicate when replacement exhaust air filter (key RESET) (after approx. 50 hours of operation, which corresponds more or less, an average use a year).
Jan 23, 2011 | Miele s558 Silver Moon Vacuum
No suction - goes to red alert even with a new bag
sounds like its blocked in pipe somewhere take hose of and push something like a long brush handle through the pipe if there's anything in there it will get pushed out
Jun 26, 2010 | Miele s558 Silver Moon Vacuum
Meile red star
Yes, this very well could be a problem with the cord reel, especially if it happened all of a sudden. There's a few ways that you can diagnosis this problem yourself. First make sure the cord is all the way reeled into the vacuum. Next find an outlet that's close, and only pull out enough cord as you have to, to be able to reach the wall outlet. After you've plugged the machine into the wall, use one hand to slowly pull more cord out of the vacuum, and use the other hand to continuously turn on and off the vacuum pushing the foot pedal that controls the main switch. Slowly pull the cord out, and turn the vacuum on and off, on and off, on and off.
At any point while you were doing this did the vacuum come on, even for a very short time? Did it even make a noise like it was trying to start? If you heard a noise, or the vacuum even came on for a time, then this definitely indicates that you have a bad cord reel.
If it didn't make a noise or come on, you still may have a cord reel problem, but you'll need to take the machine apart to further diagnosis it at this point. A simple continuity electrical tester will be needed to test the cord reel.
Here's a very detailed repair instruction that I left for a similar model Miele on Fixya already. The model that you posted the repair under is a Miele Red Star which is an S314i, the model I repaired the cord on was actually a S514. The cord repair on both of these models is identical however, except your Red Star actually has two screws that need to be removed from the variable speed control box, the S514 only has one. Otherwise, it's almost completely the same repair. If you need to purchase a cord reel for your Miele, here's a direct link to the Miele S300 series cord reel that goes with your Red Star:
Even better, if you purchase the cord reel from GoVacuum, you have 60 days after the purchase that you may return the cord reel to us if that wasn't the problem (we do test all the returns to make sure that they weren't damaged when being installed), and as long as the cord reel is returned undamaged, we give you a full refund, we don't believe in restocking or shipping fees. Better yet, we even include a return label with every order that you may use for free to avoid return shipping charges.
If you find that the cord reel is not the problem, that can only leave one of three things; the switch, the motor, or the pc control board that's on your motor. In 10 years of fixing Miele vacuums however, I can safely bet that it's your cord reel.
Anyways, here's the link to step by step instructions on how you can remove the cord to test it, as well as replacing it. If you have any questions, please feel free to use the Clarification or comment form here on Fixya, or contact us by phone. If this was helpful to you, please be so kind and rate my repair as helpful by clicking the thumbs up icons at the top of the page. Thanks so much!
How to Test & Change a Miele Cord Reel:
Chris J.
Apr 06, 2010 | Miele Red Star Bagged Canister Vacuum
My Miele Silver Moon "Reset" light is blinking. What do I do?
Greetings from GoVacuum,
Ahh yes, the Silver Moon. One of Miele's best made vacuums ever! So good that out of all the different vacuums that I could of chose for my home, the Miele S558 Silver Moon was the one I chose.
When you're Reset button is flashing, this simply means that it's time to replace the HEPA filter on your vacuum cleaner. Miele included this feature on their upper end models to alert the user when their filter needed to be changed.
The Miele Silver Moon uses Genuine Miele S-Class HEPA Filter for S300i/S600i, and Miele S7 Uprights. Miele Part # 04854915 (replaces 04854911) Which can be purchased from GoVacuum for $52.95 with free shipping.
Once you have installed the new HEPA filter, simply press down on the flashing Reset button to restart the 50 hour internal timer inside. Miele recommends to replace this filter after every 50 hours of vacuuming.
If this answer was helpful, please click on the helpful Thumbs Up icons in the top right hand corner of this Solution.
If you have a repair that you would like explained, please check out our Q & A website,
Thank you very much,
Chris Jones
Feb 19, 2010 | Miele s558 Silver Moon Vacuum
Miele, model # S 514 does not turn on.
Sounds like the cable may be damaged. I think you're going to need professional repair... sorry can't be more help.
Feb 17, 2009 | Miele S514 Solaris Electro Plus Vacuum
I have a Miele Red Star vacuum, model 314i. I bought a HEPA filter for it but am not sure how to install it.
Check it out here:
Sep 03, 2008 | Miele Vacuums
Miele s718 red light
Model S718 doesn't come up as a good model number. What did you want to know about a red light?
Aug 09, 2008 | Miele Vacuums
Vacuums Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
