Question about GE Kitchen Ranges
Replace ge downdraft switch - GE Kitchen Ranges
I need the small control module for a GE downdraft telescopic vent, part no. 959-0138-003 (ACT, Inc.). GE page does not recognize the part number. Where can I get this part?
Does anybody know where I can get a copy of the schematic for the control PC board P/N 959-0138-003 by ACT, Inc. for the GE Downdraft Vent model no. JVB98SH1SS?
Thank you.
Oct 20, 2012 | GE Profile JVB67H Kitchen Hood
Downdraft fan switch
please go to web page and fix it:
God bless you
Jul 14, 2012 | Cooktops
I have a GE downdraft vent, model #JVB94SH1SS. A couple months ago I pushed the button to put it down and it went down and up and down and up and down and up and...well you get it. I had to unplug it to...
I had the same problem. It is the switch. Hang on because that little $3 swtich is about $60 from a parts house. Sears wanted $114. If you take the switch out or disconnect the switch at the board and jumper the two leads, (12v), it should work fine. That will tell you whether it is the switch. I did it with a small screwdriver. Careful, even though it is 12v it will get yor attention. I have all GE appliances and they are all junk.
Oct 01, 2010 | GE Profile JVB67HWW 36" Telescopic...
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list -
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
Ge downdraft vent
try removing the switch from the ribbon connector, and then jumping the two pins momentarily with a screwdriver blade or other metallic tool. It could be that the switch itself is bad. This is the same problem I'm having and I am currently looking for a replacement switch online.
Jan 23, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
I just found the part that I think you need. It's part no. WB7X7220
It's available through the GE parts and accessories store.
Sep 04, 2008 | GE Profile JVB67HWW 36" Telescopic...
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut seems a diode fried or still looking for a replacement
Jun 08, 2008 | GE Profile JVB67HWW 36" Telescopic...
Order in black w/matte finish grates & downdraft cover
No. If it is really important order the grates and downdraft cover as replacement parts. This will be expensive probably around $200 - $300.
May 25, 2008 | GE 30 in. Profile JGP989 Gas Cooktop
How to replace up/down switch in downdraft vent for cooktop
Does any body know where I can get the schematic for the PC Board P/N 959-0138-003 by ACT, Inc.?
Thank you.
Jul 27, 2007 | GE Profile JVB67H Kitchen Hood
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
