Question about Andis Health & Beauty
Andis MVP clipper keeps skipping on and off I move the cord and it's fine
  • Darlene Bridge
    Darlene Bridge Dec 06, 2016
    HOw can I readjust it
    Top Expert:
  • 8,376 Answers
Sounds like you could have a break in the cord some were.
Posted on Dec 06, 2016
  • 62 Answers
SOURCE: Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Posted on Jul 23, 2008
  • 61 Answers
SOURCE: my andis clippers are experiencing
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Posted on Jan 26, 2009
billfifty
SOURCE: andis master clippers
Yeah bro.....just take off the top blade off the slider. Then you will see four screws on the slider, just tighten up each screw. The tighter you want the leveler, the harder you screw, be careful because they are easy to strip....that it, good as new....
Posted on Jul 11, 2009
SOURCE: My GTO model Andis clippers
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Posted on Jul 21, 2009
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Posted on Aug 23, 2009
What causes the andis MVP clipper cord to break
I am not sure what exactly causes it, but i would say that cold weather, excess use and improperly coiling the cord are the most likely causes.
Mar 02, 2017 | Andis Health & Beauty
Why wont my clippers power up
try moving the power cord where it exists the clipper, if it shows any sign of starting up then its probably a faulty cable.
Jul 04, 2014 | Andis Dog Clippers - AGP Super 2-Speed...
Longer better cord
Please call the Andis customer service dept at 1-800-558-9441 to purchase any replacement parts for your clipper.
Mar 21, 2014 | Andis HeadLiner LS Hair Trimmer
I ohmed out the armature on my AGC clippers. There is an open between two adjacent pads, is the armature bad?
Before you test make sure your clipper is DISCONNECTED from the wall outlet. before testingYour Andis Master clipper , I would check the electrical cord for continuity, 2 check your switch for continuity, and last your magnetic coil for open field.
Mar 11, 2010 | Andis 01690 Hair Trimmer
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
I have a Andis AGC 2 speed clipper and it keeps shorting out
No need to replace the clipper they are usually well worth repairing.
This sounds like a problem with you power cable they are just under £10, try moving the cable in different directions around the rubber strain relief coming out of the clipper.
Sep 10, 2009 | Health & Beauty
My andis clippers are experiencing blade not moving. it is not cutting.
Oct 09, 2008 | Andis 01690 Hair Trimmer
Loud andis master clipper
adjust power screw in one quarter turn
Apr 23, 2008 | Andis 01690 Hair Trimmer
Andis ag2 clippers sound loud
Check the tension of the hinge assembly which you slot your blades onto the hinge should be stiff (not moving by finger) also check the latch is connecting when the blades are fitted (check the blades wont pull off without depressing the latch. Its possible the blade drive may require replacing again they do not last long if your a busy groomer.
Apr 20, 2008 | Health & Beauty
Health & Beauty Logo
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
