Question about Crosman Boating
A stock for a crosman - Crosman Boating
How to install crosman 795 part no. 10448
The Crosman 795 Detent part #10448 is "press fit" into the rear end of the barrel therefore you can use a flathead screw driver, place it between the plastic detent and the steel barrel and gently wiggle and pry the dentent off.
Jul 05, 2014 | Crosman Phantom .177 Caliber Break Barrel...
I have a crossman phantom model cs1k77bv lost manual need to know where to put oil
Go to Crosman's web site for manuals:
http://www.crosman.com/cs/manuals/crosman-rifles
Jan 30, 2011 | Crosman Phantom .177 Caliber Break Barrel...
Pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Feb 13, 2010 | Crosman Phantom .177 Caliber Break Barrel...
How do I put trigger back on a Crosman .177 cal/66 powermaster?
See answer:
http://www.fixya.com/support/t4047835-put_trigger_back_together
Feb 04, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Gun wont stay locked when i **** it bak
I had the same problem, it wouldn't click or stay c.o.c.k.e.d when I did a typical barrel break. I took apart the back end where the3 spring was. (screw and pin must be removed once you take the barrel out of the stock.) I found that it was the "Back Spring Guide" that was broken, but not completely, I turned it, put it back together and it worked for about 9 more shots. Then the same thing happened, so I know that I need a new one. Here is the Part # B18‐00‐6 here is a link to the part breakdown pdf from Crosman's site.
http://www.crosman.com/pdf/manuals/C1K77%20C1K77X%20%20EVP%20&%20PL.pdf
I just called customer service at 1-800-724‐7486 but they close at 4:30pm eastern time, I left a message.
I cannot find anywhere online to buy that specific part, so I assume that it has to come from Crosman. I'll let you know how I make out.
If anyone knows where to get Crosman parts, please let me know.
Thanks
MD
Aug 05, 2009 | Crosman ® Quest cal. Air Rifle with 4x32...
Lost owners/users manual
go to this site http://www.pyramydair.com/site/manuals/Crosman-2100.pdf
Jul 09, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Will not pump up in order to fire
open the pump handle and spray a little WD40 into the piston tube and let the gun stand **** down for an hour or so. close the handle and try again. It seems the piston sticks and then separates from the linkage in the pump handle.
Apr 03, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Where can I purchase a Breach Seal for a Crosman Spring Air Rifle, Model C1K77? The Product # is C1K77-008. Also, Can I replace the worn out seal with a standard "O" ring (black) found in most hardware...
I don't know if you'll read this but I too Have a Crosman Phanton among other Crosman rifles. You can call Crosman at 1-800-7-AIRGUN for a free breech seal if your rifle is still in warranty (One Year) or e-mail me and I'll send you one at no charge. Don't worry I have several and don't have a problem with giving you one.
Mar 05, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Boating Logo
66 people viewed this question
Top Crosman Boating Experts
Neil
Level 1 Expert
yobo007
yobo007
Andrew Taylor
Andrew Taylor
Are you a Crosman Boating Expert? Answer questions, earn points and help others
