Question about Procom Heating & Cooling
Have a procom pck110vt shop heater. fan came on by itself,shop filled with diesel.no damaged wiring seen,plug ohms out
2 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: Dyna Glo Deluxe 65,000 BTU portable forced air
Make sure it is diesel #2 fuel as the incorrect fuel will cause it to smoke and clog the spray head. Also make sure the plug is getting good spark and the filter element is clean and unrestricted
Posted on Dec 10, 2009
Procom propane heater works fine until the fan comes on then it shuts down, works fine with fan running if the front cover is off ??? anything??
Sounds like when the cover is on it over heats. You need more air ventilation. Check for dirty filters or screen. Check whole machine. Not sure if that's the answer. Good luck.
Dec 26, 2016 | Procom Heating & Cooling
Where is the heater fan relay switch on a 1981 Isuzu pup
Blower motor fuse - IsuzuPup.com
www.isuzupup.com/viewtopic.php?t=18202
Mar 4, 2013 - Never seen a blower motor without a relay whether it has a/c or not. Just trace the wires from the blower speed switch. 1989 Isuzu Trooper S/ ... Blower motor turning instruments cluster lights on?
Apr 8, 2013
Blower motor problems
Jun 29, 2012
wiring diagram for 82 luv/pup
Jan 3, 2011
blower fan control, 81 luv diesel
Oct 14, 2009
More results from www.isuzupup.com
1981 ISUZU PICKUP 2.2L L4 DIESEL Auto Parts - RockAuto
Nov 29, 2015 | Isuzu Cars & Trucks
I.ve changed my batteries and altanator on my 1998 dodge 3500 diesel and my check gauge light is still on and my gauge reads 10
Check alternator power wire from alternator to passenger power post with ohmmeter. Should have less than 1 ohm resistance. Next check the alternator sense circuit wire (brown) for battery voltage. This is part of the 2 wire connector that attaches to alternator. If these check out I'd advise further diag at a shop to prevent potential damage to pcm. I have seen the pcm be the cause of this problem.
Mar 15, 2015 | Dodge Cars & Trucks
Pilot flame noisy and lifting on procom ml150tpa heater; how to adjust the flame
Take the valve apart and make sure the seal on coil is not damaged have also seen the snap ring come off
Mar 04, 2014 | Procom Heating & Cooling
I have a Master kerosene/diesel forced air heater. When plugged up the motor just hums. The fan turns freely until plugged up. Can I oil the motor somehow?
I don't think so. Not unless the electric motor has the two oiler ports. I have only seen oilers on older units. Newer units tend to use sealed bearings and they can not be lubricated.
Feb 25, 2014 | Heating & Cooling
Expert van 2lhdi 2005 very poor starting in cold weather had glow plugs and relay fitted still no better. i only do 3000 a year and mainly short jouneys less the 5 miles. new battery last year. it does...
Firstly fit a manual overide to the heater plugs .relay -push button type switch -wire -connectors ,run a wire direct from battery to relay ,other side to heater plug relay output so it feeds all the heaters ,push button inside cab with a 12v feed from ignition switch running to relay then other side of relay to earth ,leave vehicle on charge often on trickle charge where possible ,also on a full tank of diesel put in a litre of petrol to stop diesel waxing up ,nice old rug or blanket over engine and it will first time every time ,only use the petrol when weather below minus 5c though ,great vehicles these peugeots but i do like my ford transit
Dec 19, 2010 | Peugeot 604 Cars & Trucks
I have a 2004 suburban Z71,,,with major electrical gremlins,,,when there is moisture in the air,,,everything goes haywire,,,the headlights flicker,,,the heat or ac fan goes from high to low,,,seat heater...
I have seen a problem like this before & the problem was at the bulkhead connector.
This is a great big plug. Most are under the master cylinder area down behind the wheel well. It's mounted on the wall right above where the brake peddle is. This plug carries in the area of 30 or more wires. It connects the inside compartment wiring to the under hood wiring.It may have been damaged or even loosened at some point to find a circuit, and then not replaced &/or sealed properly. The harness itself near the bulkhead connector may have been damaged and corrosion has worked itself into the wiring & when it gets damp enough more circuits are effected.
Oct 10, 2010 | Chevrolet Suburban Cars & Trucks
I need a new knob
Did you try a web site for this unit.
It should be some instruction on the unit itself.
Jan 28, 2009 | Procom MN100HPA Heater
Pilot won't ignite
For SBP12,
It will take some time for the gas to get to the unit, just turn it on and wait. It might take 5 to 10 minutes to fill the line with gas.
Oct 20, 2007 | Procom ML300EBC Heater
Heating & Cooling Logo
32 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
