My Walker TV has a built in DVD system but I cannot get it to eject the disc even when I press the button on the side. Also even when the DVD is inside it won't play when I scroll down to DVD
  • 97 Answers
SOURCE: Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Posted on Jun 11, 2007
SOURCE: dvd will not eject
Also works for DMR-ES20DEB
Posted on Dec 16, 2007
  • 1554 Answers
SOURCE: toshiba tv/dvd combo
is there a tiny little hole you can insert a paperclip into around the front of the cd.
if so use a large one if you have it , insert and press hard to eject.
if not then you will need help.
even if you get it out the eject motor belt is likely slipped or broken.
Posted on Apr 28, 2008
SOURCE: 46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Posted on May 25, 2008
SOURCE: dvd player will not open disc, display lock
press eject and stop at the same time
Posted on Nov 11, 2009
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
How do I eject the Dvd
Press the eject button on the top right-hand of the keyboard. Be patient if the disc does not pop out immediately. Try pressing the button a few times or waiting a few seconds and then press the button again. If it doesn't eject, tilt the computer with the disc drive facing down and shake it gently as you press eject.[1]
Drag the disc icon into the trash. If the eject button isn't working, locate the disc icon on your computer's Desktop and drag it to the trash can. The trash can is located on the far right end of the Application Dock on the bottom of the computer screen.
Press and hold "Command" while simultaneously pressing "E."
Find the disc in the Finder. Open the Finder, located on the bottom left of the applications dock. Look on the left-hand side of the pop-up window under "Devices" for the name of the disc in your drive. Locate the eject button directly to the right of the disc name and click on it.
Eject the disc through an application if it is not in the Finder. In iTunes or DVD Player, click on the "Controls" drop-down menu located on the top toolbar and click "Eject Disc." You can also open iTunes and click on "Playlists" so that the left side bar pops up. Look for the CD icon with the appropriate name. Click the eject button directly to the left of the CD name.
Jul 11, 2015 | Televison & Video
Coby tfdvd3295-32in720pwidescreen lcd hdtv with dvd player hdmi input
All TVs have a tuner and a set of AV inputs for connecting other sources. A combi TV such as the Coby has one of those inputs dedicated to the built-in DVD drive. Press the Input button to see the list of sources.
The disc can be ejected either by pressing the eject button on the set itself, or possibly from an eject button on the remote if there's one fitted.
Sep 03, 2014 | Televison & Video
Cannot eject dvd from toshiba rc-1900 - remote control is working
I have same problem, the remote does not appear to have a DVD eject, despite having controls for the inbuilt DVD player. There is a button on the tv at the top left hand side, if this is pressed a couple of times in quick succession, the disc will eject.
Feb 26, 2014 | Televison & Video
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
We have a Polaroid 15 inch LCD television with a built-in dvd player. It also allows for jumpdrive connection. I must be missing something but we cannot figure out how to play a dvd. I put a dvd...
Do you have the Polaroid 1513-TDXB? I assume you have tried the eject button on the side of the TV (the lowest button next to the DVD slot). There are a few things that can cause a DVD to jam and not be recognized by the drive: put in the disc label side to the back of the TV, home disc with a glued on label (if the label comes loose), two discs in the slot or non-standard optical discs.
Some slot optical drives have a manual eject hole on one side of the slot; it should be near the top of the slot on this unit. Straighten a paperclip and try pushing on the release mechanism inside that hole. (A small paperclip is the correct size.) Sometimes pushing the optical disc with a second optical disc will bump it loose (be careful you do not want the disc to be dragged into the drive). Another possible solution is to pry the disc up off the spindle with a credit card. (Note: trying this could damage the disc and the drive.) A similar card with double sided sticky tape can sometimes lift the disc off the spindle. Stick the tape on the card, then peel the paper off the other side of the tape. Insert the card to be on the top of the disc (sticky side towards the back of the TV) and press it down on the disc. Lift up slightly and pull the card and optical disc out.
If the disc has partially ejected, two credit cards (one above and one below) can grab it. Turning the TV on its side so that the optical drive is pointing to the ground can also work.
There are a few things to check once you get the disc out. Were there scratches or other problems that would keep the drive from seeing the disc? Other optical drive issues are dirt on the lens and the tracking unit failing on the drive. Blowing the dirt out of the drive may help. Otherwise, it needs to be fixed or replaced which means getting it out of the TV.
The manual for the TV is available at this review site: . The direct link to the manual is .
I hope this helps.
Jun 09, 2011 | Televison & Video
Disc is not playing and it is not ejecting from the recorder. Before it stopped working it did the following: when the picture appeared after inserting the disc it would freeze with the picture split in...
Hi, thats is your laser lens is dirty, dusty;needs to be clean not with a dvd cleaner but manually whith alcooll and a qtips gently wipe the lens ,do not apply to much pressure on the lens while wipping and ckeck the belt for door loading mechanism if its doesnt skip.
if you have problem whit this; reply to me with some explanation on what is the problem
you experienced with the cleaning process or disasambling the machine to acces the lens.
its will be a pleasure to give you explanation on it. if the dvd recorder is a built in tv.for got all this
because its gone be to complicate to do so.../to eject the dvd out press and hold the eject button until the disc come out,if the disc wont come press pwr off wait a bit and pwr on again and press eject and hold it again til he come out.thats all i can say from here...
Merry Christmas
hope that will help you..
Regards Alan.
Dec 23, 2010 | Televison & Video
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Phillips/Magnavox 26MD255V
manual eject button is on side were you load the disc
Nov 09, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
