Question about Dryers
52-RDT REDINGTON IV STOPPED WORKING, LIGHT AND FAN! RED LIGHT ON REMOTE GOOD, POWER TO FAN IS GOOD. ANY SUGGESTIONS?
  • 52 Answers
SOURCE: 52 in. redington III cieling fan
Did you have to wire in the remote? If so you prob hooked up the light to constant power source. more info on number of wires on remote unit and wires on ceiling fan pls.
Posted on Jan 29, 2008
SOURCE: Redington IV Hampton Bay Ceiling fan lights don't work and we don't know where the receiver goes.
I have the same fan. You have wired it wrong. The receiver goes under the collar cover. It is a tight fit but it is the quietest fan I have.
Posted on May 27, 2008
SOURCE: Ceiling fan with light and remote stopped working
It's most likely the receiver for the remote (transmitter) -- it's located under the cover at the top of the fan -- will need replacing.
Posted on May 27, 2009
  • 25 Answers
SOURCE: Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Posted on Aug 16, 2009
  • 19 Answers
SOURCE: Fan not responding to remote
Check to see if the remote switches of your hand held device match the switch setting in the fan assembly
Posted on Sep 15, 2009
My Redington IV ceiling fan with remote controller is stuck at low speed. I can turn on/off light and on/off the fan but can't change speed. It just happened recently after about three years of working...
It's possible the fan is in reverse and some fans will not on function faster or lower speeds, check for a switch on the side of the fan just above the blades.
May 27, 2011 | Hampton Bay 52 In. White Redington...
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
Remote works for fan but not lights
I know you replaced the bulbs, right? There may be a loose connection on the receiver unit wiring to the lights. Check it out.
May 15, 2010 | Hampton Bay 52 In. White Redington...
Changing the light in a 54shrl
Redington III. The remote receiver is integral to the light kit. There is no replacing the light kit, you can, however change out the glass, but you're stuck with what you got.
Apr 01, 2010 | Hampton Bay 52 In. White Redington...
Remote does not operate ceiling lights or fan.
Hi fan was aorking fine then when u first turn fan on it made nosie .Now fan or light wont come on , i check power its fine
Oct 31, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Sep 15, 2009 | Hampton Bay 52 In. White Redington...
Aug 16, 2009 | Hunter 28156 Cote 54' d'AzurĀ® Ceiling Fan
May 27, 2009 | Hampton Bay 52 In. White Redington...
Fan and light stop working
Has the breaker been checked? and reset?
I would check that voltage is getting to the unit with a volt meter.
To be done only by qualified persons.
No fan power and no lights would indicate no power is getting to the unit. I would check and possibly replace the wall switch. They wear out sometimes and fail to work properly.
If you do not know how to work with AC voltage then DO NOT ATTEMPT call someone that can.
Dec 14, 2008 | Hampton Bay 52 In. Ant. Brass Redington...
Dec 11, 2007 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
109 people viewed this question
Top Dryers Experts
