Question about Ovens
I need the oven temp details.. and if possible a pic..
How to install oven igniters in Viking VGR48-6GD
Please click on the below link.You will get some ideas to replace it.Everything is explained with the pics.
http://www.explorerforum.com/forums/showthread.php?t=217691
Sep 25, 2008 | Viking 27" Professional Select Built-in...
Our Neff U1421 double oven has a problem with tripping the main fuse when the main oven reaches 180 degrees. The oven is in manual mode not using the clock timer, can you throw any light on the proble
yes i know exactly whats wrong, one of your high accuracy temp sensors will have gone.
these tell the thermo what the sides & top of the oven temp is.
unscrew the oven from the base unit & pull it out, take the top off & you'll see them little round cylinder looking things with 2 wires coming off them(see link for pic) there screwed to the shell. the one that will have gone will no doubt have burn wires, or connections.
their sometimes called temp switch sensors
http://www.bi-metal-thermostat.com/photo/pl1619154-ip00_ceramic_bi_metal_thermostat_temperature_controller_for_micro_wave_oven.jpg
Sep 29, 2014 | Neff U1421 Double circotherm Electric Oven
How do the controls on a Neff Oven B1920W0GB/02 work?
NEFF B1320A2GB Manual Page 5
just click the arrows at either side of the pic to scroll from page to page,the link starts at page 5.
Sep 05, 2014 | Neff Ovens
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
I think the oven is not getting hot enough,i have baked three
Buy an oven thermometer to check if the temperature you set the oven at is accurate. You may have a faulty thermostat, but if the temp is only off by a little, you can calibrate the temp setting on the oven by as much as + or - 25 degrees. If you have an LCD screen, then most likely you can adjust it right on there. If not, then the backside of the oven knob can be adjusted + or -. by moving a set screw and turning as needed. Your owner's manual will have a more detailed explanation on this procedure. Douglas
Jun 13, 2010 | KitchenAid 30 in. Architect II Series 4.3...
Temp control stopped working properly
replace the electronic control board.the power surge may have damaged the boards circuits.
Jan 29, 2010 | Maytag Appliances 27" Electric Double Wall...
Kebs208d THE DOOR WILL NOT UNLOCK
HI, this is a major control fault. you will need to replace the Oven control asap if possible. It has failed.
Possible causes--
*Power surge
*Failed logic(IC)
*Oven Temp Sensor failuer that has resulted in extreme temps that has overheated the board.
Jun 07, 2009 | KitchenAid KEBC207 Electric Double Oven
I cannot get the oven to come on after I used the self cleaning.
Things to check- The screw in fuses, they are usually the 30 amp fuses for the oven. Next is the clock assembly, often these clocks will have the words "push for manual" or "turn for manual", this will put the clock back into the normal operating mode rather than the automatic mode. Next, you may have to remove the power and check for any burnt wires. If all checks ok, you will have to test the selector switch and oven control.
 Oven temp problems: Temperature is too low possible trouble makers, blown oven fuse, bake element is out, burnt wire, oven probe clips, oven temp control, oven temp sensor.
Temperature is too high in the oven possible trouble makers, oven temp control, oven relay ( if used ), oven probe clips, oven temp sensor, shorted wire.
These oven probe clips often rust off and the oven temp probe hangs down, or touches the oven wall giving false temperature readings to the oven control.
Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
