Question about Sharp Televison & Video
My sharp LCD-32le265m all the while it connected hdmi to PS3 and laptop. Out of suddenly it unable to detect hdmi to devices. I tried to used the same port and hdmi connect other devices is able to.
    Top Expert:
  • Sharp Master
  • 74,251 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 07, 2016
Testimonial: "But it able to detect others devices use the same port n cable.... after hard reset, now able to detect ps3 in resolution 480 with black screen... how to solve it"
  • Michelle Lim
    Michelle Lim Dec 07, 2016
    Thanks for the advise. I did factory reset it work detected PS3 with 480p Blank screen..... but for my laptop unable to detect as well... please advise next what to do
  • 92 Answers
SOURCE: LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Posted on Mar 28, 2009
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
  • 105 Answers
SOURCE: Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Sep 27, 2009
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
I hooked up my tv,a sony bravia bx3 to my laptop using an hdmi cable which i disconnected from myps3 while it was still on,it worked perfect.suddenly the ps3 switched off.I re-connected my ps3 to the tv...
ok you have to reset the ps3 by turning of backswitch wait 10 seconds turn on the backswitch then press and hold down the front power button for 10 seconds you should hear 2-3 beeps that does it just wait and the video settings have automatically detected your tv settings and are going to ask you to save hit x to save display settings on ps3 remote problem solved. If you still get problem message me cause its technically bad.
Dec 15, 2010 | Video Game Consoles & Games
Dear sir/Madame, I?m having a problems with installing my PS3 on mine TV. TV that I?m using is a Tatung V32MCGI 32inch LCD. Problem I?m having is following. When I try to connect my PS3 on to my TV...
Have you tried "resetting" the ps3 with it hooked up to your hdmi port? When the ps3 is in standby (red light), hold the power button to power it on, however, dont let go, keep hold the button down for 5 or so seconds until you hear a beep again, let up and wait about 15 seconds and it should detect the hdmi port.
Brandon
Dec 09, 2010 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Aug 14, 2009 | Sharp LC19DV22U 19 in. LCD Television
New PS3 connected to HDMI: No picture/sound.
just hold down power button for a second beep then it will detect it.
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hdmi connection
Have you tried to select the source on the tv? If not try this. This will select the ps3
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
