Question about The Optics
Address for the service deptment for laser genetics rifle scopes
    New Friend:
  • 7 Answers
Laser Genetics Customer Service:
Phone: (954) 581-5822 (Monday - Friday 9:00 am - 5:00pm EST)
Fax: (417) 967-1069
To return a Laser Genetics product for repair, replacement or refund, ship to:
Laser Genetics Service Center
1475 S. Sam Houston Blvd.
Houston, MO 65483
Posted on Dec 23, 2016
  • 8 Answers
SOURCE: RIFLE SCOPE STUCK ON 8x POWER
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
Posted on Nov 26, 2008
  • 5 Answers
SOURCE: I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
Posted on Apr 17, 2009
  • 2418 Answers
SOURCE: rifle scope will not track with the adjustments
When you make your adjustment tap on the scope with a small screw driver handle a few times before you fire her. Work slow and tap as you go.
Posted on Jun 28, 2009
  • 115 Answers
SOURCE: looking for bushnell rifle scope repairs in Canada
the canadian office can be reached at 800-361-5702.
Posted on Oct 06, 2009
  • 32 Answers
SOURCE: i just bought a rifle with one on it. exactly how
the adjustment on the front eye PC is your zoom.
for your wind edge you have a series of numbers.
some scopes differ some read 5,10,15,etc
some read 1,2,3,4 etc, the # are estimated wind speed,left or right.if the wind isn't blowing set it on 0.
for your elevation you will have a series of #'s
50,75,100,etc.this is your yard edge sight it in at 75 yrd's and if what your shooting at is 100 yards just turn the knob to the correct setting.good luck
Posted on Nov 05, 2009
PRODUCT MANUAL Bushnell Banner Rifle Scope 4-12X40 SERIAL#V242303
Search Results
[PDF]Riflescope Instruction Manual - Bushnell
bushnell.com/getmedia/a0eb39ea.../BannerRiflescopes_1LIM_revb1013_web.pdf?... Congratulations on your choice of a Bushnell® Banner® riflescope. It is a precision instrument constructed of the finest materials and assembled by highly skilled craftsmen for a lifetime of trouble-free use under the most demanding conditions. This booklet will help you achieve optimum performance by explaining how to ...
Bushnell - Product Manuals
bushnell.com/global/customer-service/product-manuals Bushnell has been the industry leader in high-performance sports optics for over 60 years and boasts leading market share in all of the sports optics ... Service & Support Product Manuals. Product Manuals. Binoculars; Riflescopes; Trail Cameras; Spotting Scopes; Laser Rangefinders; GPS; Outdoor Tech; PowerSync ...
Bushnell - 4-12x 40mm - Multi-X
bushnell.com/hunting/rifle-scopes/banner/4-12x-40mm-2-ao,-multi-x-reticle A high-power, variable scope for long-range centerfire shooting. Banner optics are coated with Bushnell's proprietary Dusk & Dawn Brightness (DDB) multi-coating process giving you the brightness and clarity you need to fill your tag in those critical first and last minutes of daylight. Multi-X reticle; Dusk & Dawn Brightness ...
[PDF]Riflescope - Bushnell
bushnell.com/getmedia/c8da84df-a5a0-41f9-bfe0.../Trophy_Riflescope.pdf?ext... This booklet will help you achieve optimum performance by explaining how to use it's various features and how to care for it. Read the instructions carefully before mounting and using your scope. The following photographs are guides to the nomenclature and location of the riflescope parts mentioned throughout this text.
MANUAL Bushnell Banner Rifle Scope 4 12X40 Google Search
Dec 12, 2017 | Bushnell Optics
How do i mount my 650 laser sight to my bone collector rifle.
Red Laser Sight 650nm Weaver rail mount - Gamo USA
www.gamousa.com > Optics > Airgun Lasers and Lights
650nm Red Laser Sight with Weaver style rail mount.
Gamo airgun accessories, spare parts and products ' Gamo ...
www.gamousa.com/category.aspx?catID=4
Air Rifle Scope Mounts/Rails. Air Rifle Scope Mounts/Rails. Air Rifle Sights. Replaceable sights for air rifles. Air Rifle Spare Parts. Replaceable parts for air rifles.
Dec 25, 2015 | Laser Optics
How do you boresight a Barnett Red Dot 3 crossbow scope?
I use a 22 cal rifle laser on mine , the 22 is nearest the same diameter to the bolts I use so I can lay laser right into same bolt bed on frame that bolt normally rests in , then bench rest bow and get into shooting position then adj scope to bring crosshairs/ reddot onto laser dot at white target board , try to adj at distance you'd comfortably take a shot at
Sep 07, 2015 | Optics
How to use redfieeld 3x9x42 scope
Depends on the scope and rifle type to which it is attached.
I invested in an inexpensive laser bore such as this one for an AR: SightMark AccuDot Laser Bore Sight - 223 Model SM39001 (for AR-15)
Once the scope is mounted properly, and assuming you have not made any vertical or horizontal adjustments, set the rifle on a stable platform, insert the bore sight, point it at a target 50 (rimfire) to 100 (AR) yards out (works best in low light situation).
Once you have the laser centered on your target, make elevation and windage adjustments as necessary placing the scope cross hairs over the laser. Remove the bore sight and fire 3 rounds, then fine tune elevation and windage.
Dec 27, 2014 | Optics
Require an owners manual for crossman pellet rifle model 1077.
Here is the link to all the user manuals for Crossman pellet rifles
http://www.crosman.com/airguns/service/manuals/crosman-rifles
by your description you want the manual for the CS1K77
Please let me know if this is the correct manual?
Dec 27, 2010 | Crosman Optics
Have a Tasco 6-24X40MM BDC scope and need the chart for the interchangable BDC tarrets.
I have the chart for the TR624X40MM BDC rifle scope. Send me an e-mail to rmespinosa@comcast.net with your e-mail address or fax number and I can send you a copy.
Dec 08, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I need the windage dial for my Bushnell 3-9x38 Sportview Rifle Scope 74-3938. The adjustment wheel is frozen.
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Mar 23, 2010 | Bushnell 3-9x38 Sportview Rifle Scope...
NEED DIRECTIONS TO ALIGN A CROSMAN 0423 LASER GUN
should be the same as any other rifle scope. Go here for excellent instructions:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Mar 19, 2010 | Crosman Optics
Looking for bushnell rifle scope repairs in Canada
Nov 26, 2008 | Bushnell Optics
Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Optics Logo
50 people viewed this question
Top The Optics Experts
vince
geob91
Are you a The Optic Expert? Answer questions, earn points and help others
