Question about GE Microwave Ovens
My GE Advantium 120 convection oven wont come on: I checked fuse and replaced switch for oven power What ese can I do?
MicrowaveSvc
  • 9086 Answers
SOURCE: GE Profile Advantium 120 Microwave (Model SCA1000DBB03)
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
  • 234 Answers
SOURCE: GE Advantium - No power at all - PSB2201NSS01
Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
Posted on Mar 29, 2009
  • 10865 Answers
SOURCE: The door handle on my GE Profile ADvantium 120 Microwave is broke
You may consider using epoxy to "glue" the handle back into place. The epoxy will be stronger than the handle itself. If you do this get the one minute epoxy
Posted on Apr 27, 2009
dmftrucker
  • 1922 Answers
SOURCE: replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Posted on Sep 26, 2009
I have a GE Advantium Oven that just suddenly quit working...no signs of life. Could it be a fuse and if so, where is it located on the unit and where can I find one to replace it?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 18, 2011 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
No power, i have power to the outlet but nothing on the unit works.Is there a fuse?
remove the cover ... look on the floor of the unit near where the cord enters the cabinet.
Oct 12, 2009 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave power seems to have died
My advantium 120 died and it has power to the oven but it does not work! does the oven have a fuse that i can change?
Sep 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Mar 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
