Question about Dyson Vacuums
Just received a dyson v6 cordless vacuum and I'm wondering what I'm doing wrong? I have to hold the button down to run the vacuum? Is this correct?
redbeard00
  • 957 Answers
SOURCE: power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
Posted on Nov 08, 2009
SOURCE: The 'on' button isn't working/sticking
it may be possible to fix the switch before you replace it.
http://www.fixya.com/support/t1396132-off_switch_faulty
it worked for me.
good luck.
Posted on Dec 12, 2009
  • 231 Answers
SOURCE: Dyson start button will not stay on. I have to
those switches go bad all the time. replace the switch and it will be fine. let me know if you need the switch
Posted on Jan 03, 2010
  • 231 Answers
SOURCE: My Dyson DC-17 Absolute Animal does not stay
switches always fail on the dysons. its a pretty simple fix though. let me know if you need parts and/or instructions on repairing it.
Posted on Apr 13, 2010
  • 10 Answers
SOURCE: I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Posted on Jul 28, 2010
Dyson v6 surges on and off
Hello, this is Ava with Think Crucial.
There are a number of things you need to do that may solve the issue you're having with your vacuum. First, make sure that your battery is charging and working. Second, check the MAX button. If the MAX button lights up and flashes when your Dyson cordless vacuum keeps pulsating on and off, hold the power button and depress the MAX button to turn off that function. You may have to try a few times to get the hang of it. And lastly, look for any blockages in attachments because the pulsating is caused by a lack of airflow as the motor is protecting itself by pulsating and then ultimately cutting out.
You can check this video tutorial which will teach you on how you may fix it:
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 18, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
The V6 seems to be permanently on 'Max'
Hi Sandy, it's Jack at Dyson.
Our V6 cord-free vacuums have two power modes. There's regular high power for day to day vacuuming tasks, and Max mode for tackling really stubborn dirt, clinging pet hair etc.
To change between modes, you need to hold down the red on/off trigger so the vacuum is running. Then at the same time, press and release the illuminated Max button on the rear of the main body. You'll hear a change in the sound the motor makes when you switch between modes:
v6-seems-permanently-max-yb2iqq4t3gdfozzh4fdwdnjv-3-0.jpg I hope this helps. If you'd like any further advice, our experts are standing by. You can reach the Dyson Customer Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 06, 2016 | Dyson V6 Bagless Cordless Stick Vac
Recently purchased a Dyson V6 Cordless Vacuum, which has fallen several times now. Since the last fall when pushing down on the power button the noise is intermittent. Why is this?
Hi Julia, it's Jack at Dyson.
Just to make you aware, accidental damage resulting from a drop or a fall would not be covered under your Dyson warranty, so please take care to avoid this wherever possible.
If your Dyson V6 pulses on and off when you hold the trigger down, the motor is signalling that something is blocking airflow from passing through the machine. There could be an obstruction inside the floor tool, wand or bin inlet - but it's also worth checking the flap inside the bin inlet. The flap opens and shuts to prevent debris from escaping, but it's possible it could have jammed shut when the machine fell. Our video guide may help:
If you'd like further assistance after giving this a try, just call the Dyson Customer Helpline to speak with our experts. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jun 25, 2015 | Dyson Vacuums
I can't the the max mode to turn off. How do I fix this?
Hi Kayla, it's Jack at Dyson.
To switch between Max mode and regular mode, first hold down the red on/off trigger, so the vacuum is running. Then at the same time, press and release the Max button on the rear of the machine. The machine is designed in this way to make Max button can't be activated accidentally. When running in Max mode, the button will light up.
I hope this information helps, If you'd like any additional advice, you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 26, 2015 | Dyson V6 Absolute Bagless Cordless Hand...
How do i turn on boost
Hi there, it's Jack at Dyson.
In Boost mode, DC59 offers 100 airwatts of suction to tackle really stubborn dirt or clinging pet hair. To activate Boost mode, just hold down the on/off trigger so the vacuum is running, then press and release the Boost button on the rear of the vacuum. To change back to regular power, you would follow the same procedure - holding down the trigger and pressing the Boost button a second time.
I hope this helps, but you're welcome to give the Dyson Customer Helpline a call if you'd like further guidance. You can reach our experts on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 03, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
2000 chevy silverado v6 vortec 4.8 have to hold throttle wide open to start while engine running has loss of power on acceleration an backfire from exhaust system an plugs are fould out with carbon an has...
Hi David, it's Jack at Dyson.
I can see you're not looking for help with a Dyson vacuum, and if you haven't done so already you may want to resubmit your query under the correct category to be sure of receiving some expert advice.
Good like with resolving your query!
Mar 17, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Vacuums Logo
29 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
