UN40H6350 led tv with faulty pixel but only appeard when i use it for 10 minutes, if i turn off for a while and then turn on again the pixels work fine until go bad again, this is a tcon board fault?
    Top Expert:
  • Televison & ... Master
  • 75,591 Answers
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If a rest too do do not help, the main digital board is faulty, and should be replaced.
Posted on Dec 06, 2016
SOURCE: LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Posted on Feb 06, 2007
  • 18 Answers
SOURCE: 50pc5d LG plasma TV Blue glow/red pixels
THIS PHENOMENON IS A CHARACTERISTIC OF PLASMA TV SETS...KNOWN AS DIFFUSION ERRORS OR COMMONLY..SPARKLING...ON LG SETS...THE PANEL VOLTAGES MUST BE CHECKED AND ADJUSTED IF NOT WITHIN .5 V...PLUS OR MINUS..Vs...and Va...THE OTHER ADJUSTMENTS ARE ON THE Y-SUS BOARD..Vset DOWN...Vset up...RAMP up...RAMP down...these should be adjusted by professional tv personnel with experence...JOE ACE
Posted on Jun 27, 2008
SOURCE: pink and green pixels in bands on screen works on vga input only
I'm not sure how common it is, but I had this problem just recently with my Vizio. The tech came out and replaced the digital converter board and it fixed the pink and green pixels. He replaced the mother board first, but that wasn't it, so he put my old one back in and replaced the digital converter board and that fixed it. I'm not sure if "digital converter board" is the official name for the part he swapped out, but that's what he called it. Hope that helps.
Posted on Apr 26, 2009
SOURCE: 32" niko lcd-green pixelation
This is probably model OTP-311W. Problem is caused by overheating. Air flow is restricted by plastic grill over fan in back of unit at middle top. To fix, remove four screws retaining grill and fan. Take off grill, leaving fan in place. Replace screws without grill. I had same problem. Since removing grill, have now run unit for over 72 hours without pixelation problem.
Posted on Jul 31, 2009
kashanahmed4
  • 53 Answers
SOURCE: The picture is very fuzzy (pixelated) when you first turn power o
this problem occurs usually in the power supply change or check the power supply borad
Posted on Dec 18, 2009
T-CON or Panel issue HD Led TV
have tried to re-sit the flex or ribbon wires that connect to the T-Con board ? Remember some models have a very delicate ribbon cable that from from logic board to t-com board.
Feb 17, 2016 | Sony KDL-50W656A 50" LED TV 1920x1080, 200...
Problem with pixelating tv
I have "air service" (antenna) happens fairly frequently. Our Water jet causes it when it is turned on, possible same problem with neighbors, since it is usually same time of day. Other times I believe it to be broadcast issues and or weather related. I'd google for similar issues and the "width" of the problem.
Jun 07, 2015 | Samsung Televison & Video
Sylvania tv model #6842pf has vertical lines on screen what does this mean
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Jul 31, 2014 | Televison & Video
Dead Pixels on Sharp Aquos 70" LED TV
If pixels are gone on all channels - Exchange it
Can't fix it yourself unless you are tv technician
It is quite common for few pixels to be dead but that is usualy not noticable
Feb 06, 2012 | Sharp LC70LE732U LCD TV
My Samsung T4665F has a start up problem. Initially Relays click then eventually it starts up but with colored pixels over the whole screen. Then I have to switch off/on one more time and the pixels go...
This tv 100% have power supply board problems and might also have the T-CON decoders board problems too.The power supply board,that the board,where the power a/c cord plug into it.The T-CON decoders board,that the board sit wright in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.Replaced the power supply board,should get ur tv power up right away and work,no more series of clickings noises.But,if the tv still have alots colored pixels lines on the screen.The T-CON decoders board it also dead.Replaced the T-CON decoders board too.
Oct 29, 2010 | Samsung LN-T4665F 46 in. LCD Television
Dec 18, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Vizio SV470m with a pixelated screen after being on for 5 minutes
verify if it only happens on the antenna/cable input and if it works fine with dvd or other input, then it is a signal issue with the cable or antenna u r using and repair that problem and not the tv
Sep 24, 2009 | Vizio SV470XVT 47 in. LCD TV
A line of Dead Pixels.
You are right it is a stuck or dead pixel, usually if it is a colred line but not grey it is a stuck pixel at the beginning of the line you can try a utility designed to flash bright colors repetedly over time to see if this will "unstick" it. Also you could have a dry joint on your TCP which would require opening it up to diagnose.
Feb 11, 2008 | ViewSonic VA1912wb Monitor
Televison & Video Logo
Top Televison & Video Experts
