Question about GE Microwave Ovens
GE Advantium 120 no power at all: fuse ok / replaced switch What else can I do?
  • 4 Answers
SOURCE: ge advantium 120 microwave
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Posted on Dec 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: replace inside bulb
There is a step-by-step guide with photos here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
freetek
  • 5568 Answers
SOURCE: Turntable
Remove the glass table and watch the drive spindle to see if it is turning when the unit runs; just put a cup of water so the magnetron is not without load, they can be damaged otherwise.
If it doesn't turn, gently try to turn the spindle with your fingers.  If it turns manually, then the motor has failed. If it doesn't, then some foodstuff has managed to freeze the spindle.
In the latter case, pull the plug from the wall, use some foaming cleanser (it's less wet) and try to get some under or around the spindle. Let it soak overnight, then try to turn the spindle with your fingers again.  If it's now free, mop up and remove as much of the remaining cleanser as you can, leaving the table out, put a cup of water or preferably a bowl with more volume, in the unit, let it run for some minutes to try to dry the rest of the cleanser out.
Put the table back in to see if it will now turn.
If this doesn't work, it will be necessary to replace the motor.  Since this is a unit I don't know, I can't predict if it is a DIY project or not and the dealer may ask an unrealistic price for the replacement.
Posted on Sep 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken Bottom Latch Pawl GE Advantium 120 Microwave
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
SOURCE: control panel "locked" on ge advantium 120
You might have set the child lock. Look in the manual. It is on P.36 in my manual.
Posted on May 16, 2009
Looks like my GE Advantium microwave just shorted. Working fine, I hit the MicroExpress option and all power lost. Can I hit a reset button?
That is very unfortunate and I don't believe it is anything to do with what you did, just bad luck.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 01, 2011 | GE Advantium 120 Convection/Microwave Oven
I have a GE Advantium Oven that just suddenly quit working...no signs of life. Could it be a fuse and if so, where is it located on the unit and where can I find one to replace it?
Hope this helps.
Jan 18, 2011 | GE Advantium 120 Convection/Microwave Oven
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
No power, i have power to the outlet but nothing on the unit works.Is there a fuse?
remove the cover ... look on the floor of the unit near where the cord enters the cabinet.
Oct 12, 2009 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium - No power at all - PSB2201NSS01
Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
Mar 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 problem
dis connect from power alow to reset for about a minute . if not there are switches behind the door probably not making good contact make sure door is closed tightly
Jul 30, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
