Question about Health & Beauty
HOW DO I FIX A BROKEN WIRE ON A LAND LEX BROADWAY DISABLED SCOOTER
  • Jeff Tilburn
    Jeff Tilburn Dec 12, 2016
    Hi john williams, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Inline splices that crimp on the ends of the wire are the easiest to use. You can solder them back together and use shrink tubing to insulate the wires is the best way.
Dec 06, 2016 | Health & Beauty
Where can i get a landlex broadway RS user manual from ??
Hi if you have a mobility scooter then this is the link download...Hope I helped...CHEERS..
http://www.scootamart.com/media/manual/landlex-rs-broadway-mobility-scooter.pdf
Mar 18, 2016 | Motorcycles
Replacement Batteries. Can you find me a dealer
http://www.mtmmobility.co.uk/mobility-scooters-c1/used-mobility-scooters-c46/one-rehab-landlex-rs400x-8mph-road-scooter-p49 The Following products are available for free, Please select one of the following:
    • Pneumatic Tiller
    • Automatic Headlight
    • High Back Deluxe Seat
    • Delta Tiller
    • Good Condition
    This fantastic 8mph Class 3 road scooter is in very good condition, regularly serviced by MTM Mobility. With a reclining captains seat, full suspension and large wheels this Landlex Broadway RS mobility scooter with its quality 36ah batteries capable of up to 20 miles will give you all the comfort you need.
    https://www.batterybuyer.com/advanced_search_result.php?keywords=scooter+battery&osCsid=f50e0545c596ecdb777870d740d3cb39
    Oct 07, 2015 | Health & Beauty
    ON/OFF SWITCH BROKEN ON SCOOTER E100
    Replace the Red Illuminated Light On/Off SPST Rocker Switch 15A/250V 30A/125 - Switch number SWT-102050 should be available
    at most scooter repair stores or online scooter repair for about $6.00.
    Black wire goes to the Brass terminal lug. when removing the wires mark the location as Top, Center and Bottom and place the Black wire on top with the brass terminal.
    to Search Online Type 'scooter repair SWT-102050' you will see a multitude of choices
    Jun 30, 2014 | Razor E100 Electric Scooter
    Where can I find a Manual For my Landlex Broadway
    I am also looking for a Manual for my Landlex RS Broadway mobility scooter. The only one I can find is on scootermarts website and that is only the first few pages, no use whatsoever. Can anyone help?
    Oct 10, 2013 | Health & Beauty
    I have a Jazzy 614 HD scooter. The right tire seems to skip and not get traction
    The newer Pride Jazzy and Quantum series are known for motor failure where the wires become broken inside the wire insulation at the wire entrance to the motor housing - so the break can not be seen. It starts as a shutter and is intermittent.
    (The motor wire's gauge / strand count is too low for the repeated flexing when the motor articulates during acceleration and deceleration)
    Eventually the break completely and you are stuck.
    If the chair is less than 18 months old take it back to the dealer and demand a warranty replacement. If they don't fix it then contact your State Attorney General regarding elder and disabled abuse. Seriously!
    Mar 16, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
    InvaMed Sovereign Mobility Scooter Model S888NR battery charger red light flashing to indicate fault. I have a multimeter and want to know how to test the charger. I need a wiring diagram and to identify...
    Hi. Its easy to identify the pins out. Put the probes into the socket on the scooter to read the polarity. the two terminals on opposite sides will be the positive and negative battery supply. The pin to one side is to disable the scooter when the charger is connected. This terminal is normally connected to negative when the charger socket is in place.
    Most faults like this are caused by a broken wire in the charger plug orv by a faulty connection in the scooter. Sometimes the charger socket is faulty, check for heat damage or melted plastic.
    Check the battery connectors. Good luck. Neil.
    May 15, 2010 | Health & Beauty
    I want to get my scooter fixed
    Throttle wire is broken and needs to be changed.
    Simple job for any good mechanic.
    Search in yellow/white pages or nearby) for a reasonable mechanic who can do the job in your budget.
    May 30, 2009 | Transport Schwinn Rechargeable Portable ...
    Health & Beauty Logo
    101 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
